08 xb spring drop eilbach or hotchkiss
Old Jul 3, 2008 | 09:51 PM
rcdemon1's Avatar
Default 08 xb spring drop eilbach or hotchkiss
eilbach, hotchkis.anyone have the info on what lb springs they each use. i have the hotchkis on the car and my tires are barely rubbing in the front and the rear its to mushy. are the eilbach's stiffer springs.
Old Jul 4, 2008 | 02:53 AM
CIONIDE's Avatar
What size tires & wheels (including offset) do you have?
If you're rubbing on hotchkis springs, your likely options are to change springs to a milder drop, or change wheels. Knowing your tire/wheel specs will help me answer the question.
Old Jul 4, 2008 | 03:12 AM
xseveredveganx's Avatar
Utah Scions
Originally Posted by CIONIDE
...change springs to a milder drop...
NOOOOO!!!!
Originally Posted by rcdemon1
i just installed hotchkis springs on my 08 box. im running 19x8.5 with 45 offset,tires are 235x35x19s. do i need to get the camber, caster and toe in readjusted?im getting a slight rub in the front. do i need caster camber adapter plates.or is my offset wrong.
Just for you, CIONIDE!!! Let the guru do his thing!
Old Jul 4, 2008 | 03:25 AM
CIONIDE's Avatar
NOOOOO!!!!
He's got to change something! I'd rather see it low, but springs are a lot cheaper than new tires & wheels.
COILOVERS!! All problems solved!!
Old Jul 4, 2008 | 03:42 AM
Utah Scions
Heck, just check out the thread. Pictures would most definitely help...
Ninja edit..
Thread: https://www.scionlife.com/forums/viewtopic.php?t=228569
Old Jul 4, 2008 | 04:03 AM
CIONIDE's Avatar
Didn't remember the other thread... If you're barely rubbing on the front, then 225/35 tires will probably solve that issue. But when it comes to solving the "mushiness" issue, I repeat:
COILOVERS!!
Thanks vegan. BTW, what was "severed"?
Old Jul 4, 2008 | 05:11 PM
rcdemon1's Avatar
thanks for all the answers. im on 235/35 19 tires. the rims are 19 8.5s. you know how bad the roads are in los angles.i was thinking that the hotchkis front springs drop the car 1.4 and the eilbach drop it 1,2 mabe that .2 will make the difference. mabe the answer is coil overs. but dosn't that make the ride hard? and who makes the best coil overs.
Old Jul 4, 2008 | 11:18 PM
DAILYXB-TYPE-R's Avatar
i wouldn't say really who makes the best coil overs set. it just depending on your own prefference if you want more track or street and what you willing to pay for. i'm still waiting for more sets to come out and see the pricing before i buy something.
Old Jul 5, 2008 | 04:23 PM
rcdemon1's Avatar
there are pics in my gallery.....
danielv
Aug 26, 2015 07:14 PM
fcortez58
Jun 26, 2015 04:55 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
kleecker
12
Dec 31, 2014 04:07 PM
kleecker
Dec 31, 2014 09:42 AM
