Any reason why I shouldn't get DF 210s?
Old May 21, 2012 | 02:06 AM
  #41
STAYLURKN's Avatar
Originally Posted by slamdyota
because you wont get this with DFs....
did you took some of them perches off to get this low? im going this low when my wheels arrives
looks dope!
Old May 22, 2012 | 04:31 AM
  #42
slamdyota's Avatar
yes, took out the rings on the back and still have about another inch i could drop the front. back wont go as low as the front.
Old May 22, 2012 | 04:45 AM
  #43
STAYLURKN's Avatar
How many rings did you took off in the front?
Old May 22, 2012 | 04:48 AM
  #44
slamdyota's Avatar
dont take rings off the front. the strut adjusts for height as well as the spring. the rings hold the spring in place and adjust for ride heights. lower the rings go, lower the car goes.
Old May 22, 2012 | 04:53 AM
  #45
STAYLURKN's Avatar
The springs are gonna be loose if you lower the rings... Maybe you mean higher?
Old May 22, 2012 | 05:35 AM
  #46
xseveredveganx's Avatar
Utah Scions
No. The rear mount will keep the springs in place. If you lift the car, the springs could pop out, but it's pretty unlikely.
I need to remove rings out of the rear of my KSports. I'm not as low as I want to be, but front will get down easy. Don't remove front rings. You should be fine.
Old May 22, 2012 | 11:06 AM
  #47
STAYLURKN's Avatar
Ohh ok. I should be low enough with 16x8 wrapped with195/45 tires. Thank you guys!
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
rvascion
Nov 12, 2020 03:23 AM
richard_rsp
Apr 6, 2017 09:37 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
