Ingalls Camber Bolts
Has anyone installed these in the front for some negative camber? I've got a pair on order so I'll post pics once installed and figured out. I think they go as far as -2 camber up front. Thanks...
well i figure im just going to use all 4 bolts up front, the backs cambering like that just from the trd drop,8mm spacers and the offset of my rims i guess, i think that for the rear a different kit would be required for camber,
but i dont think i would want any more saw SCCA is limiting stock classes to -2 camber or some ish like that
for autocross that is lol
I got a pair of bolts since Eibach told me they were needed following lowering. However, it turned out the front camber was still in spec with ProKit. Still, I installed them anyway and used them to center the camber within the spec. The amount of adjustment depends on whether you install one or two bolts per wheel. Normally, only one is required to restore spec (none in my case). 'Course, if your intent has nothing to do with spec, then you'll probably need four !
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
Darrenohooligan
09-26-2015 07:21 AM
crimson_sinn
09-25-2015 09:41 PM
