Lowering Spring Cheat Sheet
Thought I would post this up while I'm researching what springs I'm going to go with. These are as listed by the manufactures website. If any of the info is wrong or you have any additional info, post it up and I'll edit this one.
[table
7383f753b][mrow
7383f753b]Manufacturer[mcol
7383f753b]Spring Rate[mcol
7383f753b]Drop[row
7383f753b] Tein S-Tech[col
7383f753b] 3.1/4.1 kgf/mm 174/230 lbs/in[col
7383f753b] -1.7/-2.2 in[row
7383f753b] Tein H-Tech[col
7383f753b] 2.9/3.8 kgf/mm 162/213 lbs/in[col
7383f753b] -1.1/-2.1 in[row
7383f753b] Tanabe DF210[col
7383f753b] 2.4/2.7 kgf/mm 134/151 lbs/in[col
7383f753b] -1.7/-2.7 in[row
7383f753b] Tanabe NF210[col
7383f753b] 2.6/2.6 kgf/mm 146/146 lbs/in[col
7383f753b] -1.0/-1.7 in[row
7383f753b] Eibach Pro-Kit[col
7383f753b].[col
7383f753b] -1.0/-1.2 in[row
7383f753b] Eibach Sportline[col
7383f753b].[col
7383f753b]-1.2/-2.2 in[row
7383f753b] B+G Suspension[col
7383f753b].[col
7383f753b]-1.6/-2.2 in[row
7383f753b]TRD[col
7383f753b].[col
7383f753b]-1.0/-1.5 in[row
7383f753b]Hotchkis[col
7383f753b]250/220 lbs/in[col
7383f753b]-1.38/-2.25 in[/table
7383f753b]
I was leaning towards the Tanabe DF210 but may bite the bullet and guinea pig the Tein S-Tech springs.
Edit: Still working on it
Thanks for the link on the table. Looks way better.
[table
You forgot Hotchkis and TRD, etc.
Anyways, what are you interested in? A big drop, or actual performance? Actual performance IMO, would go to TRD/Eibach Pro-kit or just go Coilovers. A big drop would go to Tein S-Tech/DF210/Sprint.
If you want to make an actual table out of it and make it look a bit more pretty... here's a little tutorial:
http://www.lots-a-bots.com/forum/php...mode=bbcode#10
Take a look, play around. Makes things like this a lot easier to read.
Well for a quality and cheap drop, go Tanabe DF210s or Eibach Sportlines (both can be bought for around ~170 bucks)
I just got off the phone with Hotchkis and they said there spring for the Xb is:
Front: 250lbs
Rear: 220lbs.
I'm working on eibach's so hopefully I'll get those soon.
Only thing a little confusing about progressive springs is that it shouldn't be a constant compression I wouldn't think. It should be soft at first and then get stiffer (progressive).
Front: 250lbs
Rear: 220lbs.
Front: 250lbs
Rear: 220lbs.
Front: 250lbs
Rear: 220lbs.
Took a quick (that means horrible cell phone picture because I don't have a digi cam lol) pic of my car with Tein Springs installed. First impression, I like them. Rides nice. Not too harsh and a big drop. I'll post some better pics after my new wheels come in tomorrow and I get them put on.
That pic looks absolutely terrible; beauty drop, but the stockies don't do it justice. I hope you went with 18's or 19's. Looking forward to the new pics. Don't forget to post all the specs for the new wheels & tires.
Originally Posted by jimchester21
how can i drop my xb 08 with the stock rim..what do u think bout the trd??? give me some advice.because the rear of xb is so high.
If you take a look at that handy chart up top, the TRDs sit right in between the Pro kit and the NF210s. Since the spring rates aren't given it's hard to say how they'll handle.
Even with NF210s I still want it to be about .25" lower in the rear. But I sometimes carry cargo and the height of the rear end changes a lot depending on what I've got in the trunk. That being said I really like the specs of the Tein H-tech springs. If I ever run into a cheap set of those I just might bite. Heck, I've already dropped my car twice - why not a 3rd time?
Also just FYI, even with only a 1" drop in the front, if you try to drive up on ramps like the ones I have pictured, the little flaps that hang down in front of the front wheels will hit the ramps. All I do to get over the hump is give it a quick burst of the gas pedal and it the car will go up the ramps. You can also run some wood boards to make the angle less steep. So basically what I'm trying to say is that with more of a drop than the TRD, NF210, Pro Kit, H-tech, you might run into those types of issues (scraping, going up ramps, etc).
CapnChunk
Apr 13, 2015 04:06 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
Scionxa180
16
Dec 8, 2014 04:00 PM
