Camber kit??
Old Aug 26, 2008 | 04:03 AM
houstonhelix's Avatar
Default Camber kit??
Is it necessary to install a camber kit when installing lowering springs? Installed TRD springs last year and I am noticing uneven tire wear.
Old Aug 26, 2008 | 04:07 AM
CIONIDE's Avatar
Camber kit not necessary, but you do need to rotate your tires, and make sure they're properly inflated, to avoid uneven wear.
I've put 15k+ miles on mine with NF210 springs (lower rear drop than TRD), rotated every 5k miles, and they look almost like new.
Old Aug 26, 2008 | 05:29 AM
xseveredveganx's Avatar
Utah Scions
I'd get an alignment. If you lowered it and haven't aligned it yet, chances are your toe's out.
Old Aug 26, 2008 | 05:42 AM
CIONIDE's Avatar
You da man vegan!
I completely forgot about that. Yea, mine drove straight and fine after the spring install, but I had it aligned anyway, and found out my front toe-in was 3x what it was supposed to be! I'm sure I'd already be on my second set of tires otherwise.
Old Aug 26, 2008 | 05:45 AM
Utah Scions
You da man vegan!
I AM on my 2nd set. And I'm pretty sure it's all due in part to not getting my car aligned after spring install.
Old Aug 26, 2008 | 05:54 AM
CIONIDE's Avatar
Neener... neener... neener.
Excellent call, though.
jcraff3
Feb 20, 2015 11:41 PM
kleecker
Jan 2, 2015 08:09 PM
Alvie
Dec 12, 2014 05:04 AM
Mr_Magu
Jan 17, 2004 05:21 AM
randode
10
Dec 11, 2003 06:05 PM
