Tire ?
Old May 12, 2009 | 03:18 PM
chizwiz's Avatar
Default Tire ?
I have 16" rims, stock 2 spoke rims. I need to get new tires. Currently the tires on the rims are 205/50 16. I am looking at 225/50 16 or 235/50 -16.
http://www.discounttiredirect.com/di...w=false&cs=225
Can I fit a 235 in the wheel well and not have to roll the fenders? I do have the NF210 springs on my ride.
Thanks.
Old May 12, 2009 | 04:16 PM
CIONIDE's Avatar
If you have the Toyota/Scion optional 16x6.5 alloy wheels, then the simple answer is yes, 235's will fit without rubbing on NF springs.
The detailed answer is that I normally wouldn't recommend going wider than 225's on a 6.5" wheel. You will have a decent amount of sidewall bulge, and while you will have a larger tread patch on the ground, turn-in and handling won't be quite as crisp as it would be with 225/50-16 tires.
The decision is yours.
Old May 12, 2009 | 04:42 PM
chizwiz's Avatar
I think I will go with the 225/50s because I dont want much tire sticking out the side, but I do want to fill in the gap in the tire well. Thanks for the response. I will get the rim size that I got and get back to you.
Old May 12, 2009 | 04:54 PM
CIONIDE's Avatar
If you're checking the wheel size, also get the offset. I gave the above info assuming that they are factory Toyota alloy wheels, which normally have an offset in the +45 range.
FYI, those Kumho Ecsta ASX tires don't come in a 235/50-16 size.
The only 235/50-16 tire that I know of is the Toyo Proxes T1-R, and it runs about $150 per tire.
Good decision to stick with the 225/50's.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
love2accelerate
May 9, 2016 10:19 PM
evolving_machine
Scion xB 2nd-Gen Wheel & Tire
12
Jan 18, 2016 08:41 PM
ptperson
Regional - Pacific Northwest
Feb 13, 2015 04:03 AM
