tire pressure for 18's?
Old Feb 11, 2009 | 04:50 PM
melcoeb's Avatar
Default tire pressure for 18's?
what's the tire pressure you guys use for 18's?
Old Feb 11, 2009 | 04:55 PM
alltattooed's Avatar
That will very from tire to tire.
Your best bet is to fill to the spec's that are on the tire.
good luck!
Old Feb 13, 2009 | 03:14 AM
TerribleTed's Avatar
I run my BFG G sports at 26 in the front and 30 rear. The lower front pressure improves the ride alot and with these particular tires wear is even at this pressure (would be even at 30 also I am sure).
Old Feb 13, 2009 | 04:10 AM
curtisc's Avatar
It really depends on the size of the tire. Also, what is listed on the tire is usually the maximum pressure, not the best pressure your particular car/tire combo.
Old Feb 13, 2009 | 03:29 PM
xravexboix's Avatar
It will vary based on the type of tire, size of tire, etc. I would recommend starting at the vehicle's recommended and slightly over inflate (+3) and see how you like it. Slightly underinflate the next time to see how you l ike it. Choose accordingly after both tests.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
kingofthecrate
Jan 21, 2015 09:28 PM
JDMxB
23
Feb 26, 2004 06:16 AM
Strader
Oct 12, 2003 11:46 PM
