2011 xD will not Start..
Old Dec 27, 2018 | 08:06 PM
Woody43's Avatar
Default 2011 xD will not Start..
This car stopped on drive home, had TPS codes replaced throttle body, still no start.
Had throttle peddle code replaced throttle peddle now no codes but still will not start!
Any ideas?
______________________________
Last edited by MR_LUV; Dec 27, 2018 at 09:11 PM. Reason: Moved to Correct Forum by Administrator
Old Dec 28, 2018 | 10:20 PM
DAlex's Avatar
Maybe you should take it to a mechanic before blowing any more money on unneeded parts?
Old Dec 28, 2018 | 11:11 PM
RyanL's Avatar
Well if he got codes related to the tps then I'm sure they would've replaced the same exact part. And then they would've still charged you for the "unneeded parts" anyway (been down that road before).
Old Dec 28, 2018 | 11:19 PM
RyanL's Avatar
Any ideas?
It's quite possible you did fix the issue but need to do some sort of "learning" procedure for the new TB/TPS. I had Nissan a few years ago and had to do some sort of dance after I replaced the TB (drive by wire system like I believe your car has too).
Hell, replaced a TPS not too long ago on a 90s Toyota truck and had to set the TPS just right in order for it to work (had a slight adjustment to it and had to set it just right with an ohm meter). Just throwing a couple of suggestions out there wish I could be more help.
________________
hobojon
Apr 25, 2021 10:24 AM
Bobsponheim
Apr 30, 2018 02:30 PM
SJ11
Jun 6, 2017 05:42 AM
Matts6345
Dec 8, 2016 07:13 AM
zakvlm
May 23, 2016 02:52 PM
