2ZZGE Engine Swap
Old Aug 13, 2010 | 10:28 PM
mixD's Avatar
http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
here you go this one is running the tc engine that would be a pretty good swap for our car!
Old Aug 13, 2010 | 10:45 PM
xD_kidd91's Avatar
That's actually our engine. They didnt even accurate info to what engine their using) Toyota "2.4L 1NZ-FE"?
Old Aug 14, 2010 | 04:17 AM
JDMJim's Avatar
thats a hell of a stroked 1NZ
Old Aug 14, 2010 | 07:23 PM
ohcrap's Avatar
OK so here's the scoop from JE Import Performance. I had a meeting with James, the owner, this morning. First of all, holy crap, I had no idea they had so many over the top, cover feature, creations... really impressive. So here's what we discussed as far as development for the xD:
Custom Intake:
- Yes, they can absolutely do it, they do them all the time
- 1st person will be the guinnypig, $1500, initial dyno, R&D, CAD, fabrication, testing, ect.; recommends upgrading fuel pump but injectors probably not necessary
- The guinnypig will then use it for 200 miles or so to test; refine if necessary; dyno to determine gain
- Once complete, they will have it manufactured by Sikky (sikky.com) and added to their parts list
- Group buy of 10 or more would likely run $800, 5 - $1200 (estimate); would require $500 down each
- BTW, he said the custom intake in the pic I posted was horrible and the wet-nitrous setup was all wrong
Wire-Tuck:
- $85-$90 per hour; guesses about 5 hours for very clean result
Turbo:
- Custom set-up, Garett turbo, eManage Ultimate, upgraded injectors and pump; recommends about 8psi on stock motor, maybe less for auto trans (would require some research - anyone know if we can beef up the xD auto trans? How? Who?);
- $3K-4K for parts; $500-$600 for install (estimate)
- May also require clutch upgrade
Motor Swap:
- "We can and have, put just about any motor into just about any car"
- 2ZZGE swap; ballpark estimate - 5K
Old Aug 14, 2010 | 08:26 PM
xD_kidd91's Avatar
thank you very much sir
it seems to me that its very reasonable.
I figured the 2zz swap would cost about that much. im assuming that includes motor. trans and ecu.
for an xd trans. im only guessing that it can be compatable with the corolla trans from the previous gen.
I we can get 10 people for an intake I sure would be down. Dynatek was able to put out 15hp before they went out. I'm also considering The turbo option Cause I'm sure we can get atleast 230hp on 8 psi if the 1zz can do it
Old Aug 15, 2010 | 05:58 PM
Zefoxe's Avatar
Theres someone from PR that used to be on here who turbo'ed their 2ZR and blew it and then did a complete 2ZZ swap and said it was better engine for the car.
Old Aug 15, 2010 | 08:20 PM
ohcrap's Avatar
ROYALJAPANESEMOTORS.COM
"We have the celica GT 1.8 Non turbo , the engine alone cost $1100:oo plus transmission will about $750:oo plus shipping , depending on your address .
> If you are serious , I could make it shipping included"
Old Aug 15, 2010 | 09:37 PM
xD_kidd91's Avatar
That's the 1zz engine. That's pretty much how much they cost nd we basically have a corolla .. the gts is 2zz. That cost roughly 2200. Then trans prolly a gran
Old Aug 17, 2010 | 05:48 PM
ohcrap's Avatar
I"m not going to do it but good catch, right you are. Thanks
Old Aug 17, 2010 | 05:56 PM
ohcrap's Avatar
Question #1: I may volunteer to be the "guinny pig" for the intake but would getting this made and put on my car have any effect on turbo'ing later if I decide to to so?
Question #2: I read somewhere on this forum that there was a bottleneck in the xD exhaust from the header to the first factory cat... is this a downpipe? If so, do you happen to know the diameter of the factory one? Because I spent big on a custom 2.25 mandrel bent, stainless exhaust and was thinking of finishing it out with the larger diameter Weapon-R headers and a custom downpipe (if what I said above is true about the bottleneck), then the custom JE mani with upgraded fuel pump to keep up.
JonathonK
Mar 22, 2018 09:00 AM
VitaminE
Mar 24, 2015 03:36 PM
churrosurf
Jan 30, 2015 01:12 PM
trickedxb
9
Jan 16, 2004 07:34 PM
Torokun
21
Sep 25, 2003 03:02 PM
