Scion xD ICE & Interior In-car entertainment and electronics...
Cover inside Door Handhold?
Old Mar 22, 2021 | 11:50 AM
Superiorkolours's Avatar
Default Cover inside Door Handhold?
Hi guys, I'm new here. Just bought a 2010 xD. I was just wondering if there is a cover or little rubber mat or something that goes inside the hand hold area on the doors?
The area behind the window switches where you can put your fingers to pull the door shut.
I was cleaning the door and when I look down in it there is a bolt down in there like on most doors and around it was dirty. I'm having a hard time cleaning it.
Usually there is a little flat rubber mat that goes over top of these areas or a cap or something that you have to get a pick in there and pry up to allow access to that bolt.
I looked on Toyota parts diagram but can't find anything. Can someone tell me if there doors have a cover or something covering the bolt head?
Old Mar 22, 2021 | 02:35 PM
Birsan's Avatar
@Superiorkolours Hi, I have a Scion xB 2004. On this car there is same black color screw. Newer was covered. Eventually with the passing time, the head that is not cover will become rusty, and from time to time needs to be spray painted. The mechanic need to have access to this screw to replace the door locking plastic damaged parts, replace the damaged window electric motor, and much more...
I do paint this screw with dark color spray paint (black, brown, blue, gold...it is depends which spray cans, I will find in my place older). The paint that I use must be rust proof and made for exterior.
Old Mar 22, 2021 | 03:40 PM
Hey thanks. That's odd there usually is some sort of cover or little rubber mat or something that goes over top of these and you have to pick them out. I just thought maybe this car was missing them.
Old Mar 22, 2021 | 04:59 PM
MR_LUV's Avatar
Administrator
Administrator
After lengthy Research and Fine Tooth Combing through many Diagrams, I THINK this is what you are looking for.
Hope this Helps,
MR LUV
__________________
Old Mar 22, 2021 | 05:49 PM
Hope this Helps,
MR LUV
__________________
I think you are right! You are the man!
74222-52030 LH
74221-52030 RH
Just wanted to follow up. These part numbers were right. just got them, almost feels like felt lol, but it covers up the bolt nicely.
Old Apr 10, 2021 | 07:05 AM
BatryOperatedBoy's Avatar
Sounds like a trip to a fabric store might be better. Or maybe some kind of cut up mousepad?
itscurtsk
10
Nov 28, 2012 03:53 AM
monoxide101
Dec 16, 2010 11:58 AM
HondAudio
11
May 22, 2008 04:50 AM
noservice2001
Regional - Islands
Mar 5, 2008 07:44 AM
goldenarches69
Mar 10, 2005 05:08 PM
