Scion xD ICE & Interior In-car entertainment and electronics...
Karr alarm keeps going off/won't disarm.
Old 10-29-2012, 10:06 PM
kaemo's Avatar
Default Karr alarm keeps going off/won't disarm.
I've had my 2009 Scion xD now for three years now and never knew I had any sort of anti-theft/alarm system until a few weeks ago. Here's what happened.
A few weeks back, when I pressed lock on the key fob, my car honked instead of doing its normal beep. I didn't think anything of it, as it's never happened before. I wasn't even sure if it was my car. But the next day, it happened again and shortly after, the horn started honking and nothing I could do would turn it off. I tried locking and unlocking with the key fob and manually. I tried the panic button. I tried starting my car but it wouldn't even click over or anything. Every time I locked, unlocked, opened the door, put the key in the ignition, or did anything, the alarm would go off and I couldn't get it to stop. I had AAA come out and they said the battery was perfectly fine. Finally, after a few hours, the car honked three times after removing the key and the alarm started. But hitting unlock on the fob stopped it and I was able to start my car.
I had no issue with it until a week and a half later. The entire scenario happened again. There was a blue light blinking under the steering wheel that I had never noticed before.
Any time I tried to lock or unlock my car or open the door or start it, the alarm would start honking and nothing could make it stop. Finally, an hour later, I was able to start my car randomly.
I've since learned there is a Karr system installed with a normal Scion key fob. I've looked for a valet switch or button under the kick panel and dash and there's nothing. I've located the brain of the system
but none of the wires lead to any button that I can see. I've tried to replicate what I've done in the past to get the alarm to engage but nothing has worked. It just seems to randomly activate (so that I can't start the car) and deactivate.
Does anyone have suggestions on what I can do if this happens again so that I can deactivate the system without having to wait an hour or more to be able to start my car?
Or does anyone know how to take the whole system out? I didn't even know I had it and it's proved to be more trouble than it's worth.
_____________
kaemo is offline
Old 10-06-2018, 05:42 AM
Tiffy____'s Avatar
Default Did you ever get it fixed?
I doubt you will reply 6 years later. But has this happened to anyone else? This just happened to me today. I have no clue what to do!!
Tiffy____ is offline
Old 02-10-2019, 04:59 AM
Eloranrange's Avatar
did you get it resolved? I moved the wires wire of the alarm and it stopped since one cable is disconnecting.
Eloranrange is offline
zoiks
21
11-11-2015 01:15 PM
Mikeydizzle
12-29-2007 06:38 AM
SengTC3
07-22-2007 02:48 PM
jonathancasilli82
09-15-2006 09:25 PM
Lenalove
10-06-2004 08:12 PM
Quick Reply: Karr alarm keeps going off/won't disarm.
