Scion xD ICE & Interior In-car entertainment and electronics...
New head unit problems
Old Jun 20, 2012 | 05:13 PM
Kylevh21's Avatar
Default New head unit problems
My wife just bought a 2012 scion xD and I put a double din jvc from her Toyota yaris in her xD and now the hazard light an clock don't work
Can anyone help me ?
Jvc head unit works great other than that
Old Jun 20, 2012 | 05:19 PM
awisher's Avatar
a few options here:
1. you didn't securely reconnect the center panel cable to wiring harness
2. you connected the wiring to the stereo not the center panel. Doing this even quickly leads to...
3. blew a fuse. check the dome light fuse under the hood. Do the map lights and dome lights work? if yes, it is probably 1 or 2
Old Jun 20, 2012 | 05:24 PM
Kylevh21's Avatar
Yes that map lights work
I'll have to check fuses and see if it's the right harness plugged in
Thanks for getting back to me so fast
I'll let u know if I get it to work tomorrow I have to sleep before work tonight
Old Jun 20, 2012 | 08:36 PM
awisher's Avatar
It is my understanding that there are several fuses involved with interior lighting and stereo. There is the dome light one in the engine compartment and at least one or two 'ACC' ones in the fusebox above the drivers left foot.
Old Jun 21, 2012 | 12:16 AM
firstkingofbeer's Avatar
yeah it sounds to me like you didnt reconnect the clock/hazard lights. its easy to do, just pull the cover back off to make sure it is connected.
Old Jun 21, 2012 | 06:51 AM
Kylevh21's Avatar
I check te connection and it's plugged in all the way
I'm going to unhook the head unit and see of the clock comes back on
Old Jun 21, 2012 | 05:05 PM
awisher's Avatar
I would pull the fuses and check them first. it will be easier.
pull the one in the engine bay first then then the 2 in the cabin.
Old Jun 22, 2012 | 02:53 AM
Kylevh21's Avatar
Figured it out had the wrong harness plugged up lol
Everything works great my wife loves the double din watch DVDs on road trips
Old Jun 22, 2012 | 03:01 PM
awisher's Avatar
good to hear... enjoy!
Old Jun 22, 2012 | 09:07 PM
Swbari00's Avatar
did you accidentally switch the clock harness and radio harness? They are the same plug and I sure did that the first time I messed with my radio.
Old Jun 22, 2012 | 10:28 PM
Tomas's Avatar
Admin Emeritus
Sounds like an excellent opportunity to mark the connectors (I usually mark 'em as I take 'em off).
Old Jun 23, 2012 | 04:47 PM
Kylevh21's Avatar
yeah it ended up being the harnes for the usb plug with i have plans with
im going to get a male usb connector and cut the wires from the harness and wire it up for the aftermarket head unit so i can use the cars usb outlet instead of the usb plug in the glovebox
wiltonhall
Jun 23, 2025 10:09 PM
sehall6h
Feb 21, 2016 04:28 PM
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
clickclickw00t
Feb 18, 2015 08:57 PM
billzor
Jan 17, 2015 12:38 PM
