Scion xD Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
xD Rear Spacer Shims Install w/PICS ~ Now Available ~
Old Nov 12, 2009 | 12:16 AM
YELOSUB's Avatar
Wagonistas
Originally Posted by randode
looks great Tim.
10mm are now in stock. 5mm and 13mm coming soon.
I believe 5mm and 13mm in stock now also along with the 10mm Way to go Randode !
Old Nov 12, 2009 | 03:48 AM
uskrewed's Avatar
So..... what's with that Kia? haha
Old Nov 12, 2009 | 04:31 AM
YELOSUB's Avatar
Wagonistas
Umm, you mean Cube He bought it so that he could start making aftermarke stuff for them since he already did stuff for Scion...Kinda like a business venture...
Old Nov 12, 2009 | 05:12 PM
uskrewed's Avatar
Right, the cube is nissan and the kia is soul. I get them mixed up. I can't believe he makes enough money to afford to buy a car just to mod it. Kudos to him. And another "wow" at the xD. Sorry to hear about having to remove the spacers
Old Nov 13, 2009 | 02:39 AM
YELOSUB's Avatar
Wagonistas
I should be able to run spacers again when I run different size tires...But that wont be for awhile, these damn tires are hard and barely show any wear
Old Feb 6, 2010 | 11:54 PM
YELOSUB's Avatar
Wagonistas
Mods do you think we could sticky this? Don't see another actual xD thread on a "How To" install spacer shims...
Old Feb 16, 2010 | 02:12 AM
eight08customs's Avatar
sweet man.. maybe if you used a smaller tire like a 215 35 18 the rubbing issue will go away.
Old Feb 16, 2010 | 03:28 AM
YELOSUB's Avatar
Wagonistas
Yea, I need my tires to go bald ...The stupid things wont wear down fast enough...I think I wanna run a stretch though, thinking 205/40/18...
Old Aug 1, 2011 | 08:31 AM
itscurtsk's Avatar
you didn't explain what to do with the 4 bolts that come with the shim. all i see is that you lined up the shim and the back plate. then bolt the hub back on with the 4 bolts you have taken off.
Old Aug 1, 2011 | 05:24 PM
YELOSUB's Avatar
Wagonistas
Go back to page one and look at the first pic...It shows the shim and the (4) supplied bolts that come with each shim...And then further down the in the photos during the reinstallation process you will see this quote "put some red loc-tite on the supplied bolts and bolt the hub back on. Leave the bolts loose until all four have been started. Torque to about 40 foot pounds." I'm not sure I understand what you are trying to ask...
Old Aug 1, 2011 | 06:30 PM
itscurtsk's Avatar
in order to bolt the hub back on, aren't you using the (4) 14mm bolts that you took off in the beginning? i don't get where the supplied bolts come in. then a total of 8 bolts are used for each side?
Old Aug 1, 2011 | 06:50 PM
cobaltbravo's Avatar
you dont use the original bolts. you put them in a drawer in your toolbox, just in case one day you want to take the car back to stock. you use the longer bolts that came with the shims to bolt the hubs back to the axle. i dont think it can be explained any simpler than that.
Sent from my rooted Droid
Old Aug 1, 2011 | 06:53 PM
YELOSUB's Avatar
Wagonistas
Thanks...
Old Aug 1, 2011 | 07:15 PM
itscurtsk's Avatar
thanks, that cleared things up.
Old Aug 4, 2011 | 11:32 PM
itscurtsk's Avatar
so I tried doing this on my 05 xA. I process should be the same I hope the only difference are the 5 lug vs 4 lug. I attempted doing one side, I couldn't remove pull off the hub. Tried sticking a flathead between it and getting it off but still didn't move so I gave up. Anyone know why?
Old Aug 5, 2011 | 01:24 AM
YELOSUB's Avatar
Wagonistas
Just talked to Randode...He says, set parking brake TIGHT ...There is no need to pull the drum or even the wheel off...Simply remove the (4) bolts on the back side of the hub assembly...Don't forget to disconnect the ABS wire...Once the bolts are out and the ABS wire is disconnected, simply pull on the tire far enough so it allows you to slip the new spacer shim in place....
Any question, don't hesitate to text RANDODE @ 602-904-0542...
Old Aug 5, 2011 | 07:06 AM
itscurtsk's Avatar
this is gonna be a 2 person job since i need someone to hold the entire wheel up, slide in the shim and align everything together so i can insert the supplied bolts. thanks for the advice and number. i'll take pics if i can.
Old Aug 5, 2011 | 08:26 PM
midnight_king's Avatar
Here are some more FUN shots I took...Man I wish I had coilovers...Looks sick when you can tuck...The Cube is Randy's that he just finished bagging...Of course he's not satisfied because it's not low enough, so he will cutting things eventually...
i know this is a hella old post, but you were saying that this was you on TRD springs?
Old Aug 6, 2011 | 06:26 AM
YELOSUB's Avatar
Wagonistas
Ya but dont let the curb picture fool you...It was taken at an angle and emergency brake pulled...Now that im running Tanabe DF210's and a heavy a$$ system, I tuck rear all day long...
Old Aug 6, 2011 | 04:00 PM
htheduck's Avatar
Nice effort Yelosub,
But in a nutshell can you sum up why you want to stagger your rears by 5 or 10mm per side?
Is it for a look to match the wheels or adjust handling characteristics?
(Because I don't understand what 'tuck' means).
Thanks.
