My new xD had 50 PSI in the tires off the lot..
Old Aug 11, 2008 | 03:13 AM
NetworkShadow's Avatar
Default My new xD had 50 PSI in the tires off the lot..
The subject says it all. The tire pressure light was on, needless to say.
I assume that I should keep the PSI down to the suggested 35 PSI. I just took the PSI down to 40 tonight and the tire pressure light started blinking instead of staying on... I guess I'll let out another 5 PSI tomorrow.
What is everyone's experience with the stock 16" tires?
Old Aug 11, 2008 | 05:18 AM
Zefoxe's Avatar
Surprisingly smooth. TRD springs don't help though
Old Aug 11, 2008 | 03:28 PM
The_Sc10nt1st's Avatar
Default Re: My new xD had 50 PSI in the tires off the lot..
I would keep the tires inflated to what it says on the driver's side door panel sticker (make sure to check the inflation while the tires are cold -- i.e. have not been driven for at least 3 hours).
I imagine some helper-monkey at the dealer probably just overinflated your tires by mistake. When I took mine home it had the light come on too (underinflated on one side)
I found that my 18" make the light come on when they're a few PSI over or under the recommended amount. I'm sure it's the same with the 16" tires.
Old Aug 11, 2008 | 05:14 PM
Thanks for the tip. I just thought it was odd that they were at 50PSI and wanted to make sure 35PSI was best for the 16" tires.
Old Aug 28, 2008 | 06:20 PM
xDeals's Avatar
I had 60 PSI in one tire on tuesday. I can't explain how it happened. I've had the car for two months, everything has been fine. Then I get the warning, bring it into the shop I work at, and they ask me "wtf did you put 60 PSI in your tire for?" I didn't even touch it. I don't get it. I also notice other things in my car that I didn't do. Sometimes the vents are all closed on the dash, one day my back seat headrest was up, and the next day it was down and the other headrest was up. I don't know...xD ghosts?
Old Aug 28, 2008 | 06:54 PM
xravexboix's Avatar
The tire pressure sensor has to be "initiated". To do this (not sure on the xD, but I had this happen on my 4Runner), it has to be inflated to 50-60 PSI and then the air can be let out. That activates the sensor and the light will go away.
The light SOLID means you have to check the pressure.
The light BLINKING means you have to get it checked @ the dealer. It's either not initialized yet (I picked my 4Runner up before they completed all the system checks), or something is really off in the system.
Old Aug 31, 2008 | 08:45 PM
OPINIONATOR_xD's Avatar
looks like the dealer forgot to set psi during predelivery inspection.
Old Aug 31, 2008 | 08:52 PM
AC's Avatar
AC
they come off the truck overinflated just in case the car sits for a while. there will be flat spots if they sat for a while and not overinflated, which will cause a vibration.
Old Sep 20, 2008 | 04:00 PM
CXT's Avatar
CXT
DEVIANTS!
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
my06tc
Jun 25, 2015 12:18 AM
knepart
Scion FR-S Forced Induction
Apr 25, 2015 02:48 PM
B_Real45
Feb 23, 2015 07:33 PM
JDMxB
23
Feb 26, 2004 06:16 AM
