Headlight problems
Old 01-20-2018, 07:19 AM
houtxdrew's Avatar
Default Headlight problems
Sup guys. New to these forums page, I have a 2013 tC and I'm having issues with my Headlights.
Seems like the Projector isn't shining the light correctly.
Doesn't have the straight cut off line nor they shine on the road as they used to.
Any tips on what to do? Thanks
Last edited by MR_LUV; 01-20-2018 at 02:16 PM. Reason: Moved to Correct Forum by Moderator
houtxdrew is offline
Old 01-21-2018, 09:32 PM
Administrator
Administrator
MR_LUV's Avatar
Originally Posted by houtxdrew
Sup guys. New to these forums page, I have a 2013 tC and I'm having issues with my Headlights. Seems like the Projector isn't shining the light correctly. Doesn't have the straight cut off line nor they shine on the road as they used to. Any tips on what to do? Thanks
Your Vehicle is now over 4 years old. One of the first symptoms of a bad or failing headlight bulb is Dim Head Lights. Over time headlight bulbs can wear out and begin to shine noticeably dimmer than when they were new.
A dim headlight will not provide proper illumination and is also usually a sign that the bulb is approaching the end of its service life. Also besides the bulb itself, but could be somewhere in the wiring leading to the bulbs.
Common reasons for this to happen:
Corroded Ground Wire
: One of the most common causes of dim headlights is a corroded ground wire. Ground wires connect the bulb circuit to your car’s chassis (which serves as the ground itself).
If corrosion develops on the wire (or the connection is dirty or damaged), it disrupts the flow of electricity, often enough to limit the output of your bulbs.
Discoloring Deposits
: This is particularly common with halogen type light bulbs. Over time, the inert gas within the halogen bulb creates a discoloring film (brown or gray). This builds up on the inside of the bulb and dims the light output. Replacing the bulb is generally the only option here.
Bad Alternator
: Another very common reason to see dim headlights is a failing alternator. If you notice that the lights brighten and dim as the engine revs up and down, the alternator should be checked immediately. If it fails, dim lights will be the least of your problems.
The car will begin pulling power from the battery and because it’s not being recharged, it will eventually drain completely. This will leave you stuck on the side of the road.
Yellowed Lenses
: Often, dim lights have nothing to do with the flow of electricity or aging bulbs. Rather, they have to do with the aging of the headlight lens (the large plastic cover that protects the bulbs inside).
Lenses yellow as they age, and this affects the amount of light that can escape and limits your visibility at night.
Loose Alternator Belt
: Dimming lights may not be a sign of a bad alternator. It might be a loose alternator belt instead. If the alternator belt is loose, it doesn’t turn the pulley correctly (it slips and then grabs, slips and then grabs).
This can be noticed in dimming and brightening headlights.
The belt should be checked for excess play, as well as wear and tear.
MR_LUV is offline
Vince2133
06-27-2011 03:13 AM
HeadlightArmor-com
Scion tC 1G Aero & Exterior
06-13-2007 02:58 PM
HeadlightArmor-com
14
10-04-2006 07:53 PM
HeadlightArmor-com
09-11-2006 08:55 PM
DJ_OVERGOLD
12-08-2003 07:38 AM
Quick Reply: Headlight problems
