tC G2 Tech and DIY Info for the Scion tC G2
DIY Permanent, NON paper, door rattle fix.
Old Jan 13, 2012 | 10:57 PM
Xander451's Avatar
Default DIY Permanent, NON paper, door rattle fix.
This is a permanent fix for the rattling in your door that will stop about 98% of the rattling and it only costs about 4 bucks.
Time to do: Approx. 5 mins per side
Materials needed:
-Scissors
-and this craft foam stuff from walmart:
Driver Side.
Step 1: Remove the window/lock controls
Pull up here, there is a hook at the other end that will break if you try to pull up there.
Then pull back to remove the controls.
This is that hook I was talking about.
Step 2: Cut strips of the foam sheet and place anywhere that is flat. (I used a black sheet of foam but you can use whatever color you want because it doesn't show once the controls are re-installed.)
This is how I did mine.
Step 3: Re-install the controls in the opposite way they were removed making sure that the hook at the forward end goes all the way forward before you snap everything down.
Congratulations! You've just silenced that annoying rattle and now you can enjoy your music as loud as you want with very very little rattling if any.
Passenger side installs the same way.
Old Jan 13, 2012 | 11:28 PM
MightyP's Avatar
Where did you find the foam?
Old Jan 13, 2012 | 11:30 PM
Xander451's Avatar
I got it from Walmart in the craft section but I'm sure any arts and crafts type place would have it too.
Old Jan 13, 2012 | 11:50 PM
biglilsteve's Avatar
I love it man. Nice DIY.
Old Jan 14, 2012 | 12:23 AM
Xander451's Avatar
Thanks! As I get my hands on more parts I'll post more write ups
Old Jan 14, 2012 | 01:30 AM
itscurtsk's Avatar
is it the rattling noise when you bump up the bass?
Old Jan 14, 2012 | 01:33 AM
You don't even really have to bump it up. I would experience the rattling at very moderate volumes where I'd think to myself, "now there is no way my music is loud enough to be causing this!"
Old Jan 14, 2012 | 03:28 AM
Xander451's Avatar
Yeah the music rattle not the window rattle that some people have been getting.
Old Jan 14, 2012 | 04:23 AM
tyap's Avatar
Wow. Nice! Thanks for the post!!!
Old Jan 14, 2012 | 03:37 PM
StreetSweeper's Avatar
U should hear the back of my car....it makes all kinds of noise.
Old Jan 14, 2012 | 04:17 PM
Xander451's Avatar
Any ideas on where in the back the noise is coming from?
Old Jan 14, 2012 | 04:20 PM
Yeah now that the door vibration is just about gone I can hear the back of my car vibrate when the JL hits.
Old Jan 14, 2012 | 09:03 PM
pieceoflettuce's Avatar
Nice tutorial, I'm doing this atm, but I cant get the panel snapped back on...the side closest to the door wont snap back in...??
Old Jan 14, 2012 | 10:54 PM
Xander451's Avatar
Pardon the french but snack the sh*t out if it abs if that doesn't work then take a sharp blade to the foam in that area and take off a thin later if foam.
Old Jan 14, 2012 | 10:57 PM
Xander451's Avatar
Sorry about the typos, using my phone to respond and my auto correct sucks
Old Jan 14, 2012 | 10:59 PM
Xander451's Avatar
For this I would suggest pulling all if the plastic panels off and use something like dynamat to dampen the vibrations.
Old Jan 20, 2012 | 12:34 AM
CrispyFShacker's Avatar
Thanks a lot it worked great. My Walmart only had the huge pack so now I have tons of multicolor peel and stick foam . I do still get some vibration from one side you didn't place any foam I'm gonna take it off again and see if I can get a thin piece on that sodr
Old Jan 20, 2012 | 12:43 AM
MightyP's Avatar
I bought the foam tonight and had the same thought. "Holy crap, I need about 1/4 of 1 sheet and I have 6 sheets???" Guess I'm gonna be foaming a bunch of stuff.
Old Jan 20, 2012 | 12:55 AM
KidJustin's Avatar
DaYUUM/Scion Evolution
lol, foam the whole inside of ur tC2 for extra protection when u AutoX
Old Jan 20, 2012 | 01:16 AM
MightyP's Avatar
Just went out and actually did the mod. Works great. As clean as 6x9 speakers can sound!
But I lied, I didn't need 1/4 of the sheet. I needed about 1/32 (if that) of the sheet. As thin as you cut the strips, 6 sheets works out to miles of foam.
After you buy the pack for $4, don't just do your car. Do all your friends' cars! Do their friends' cars! In fact, do all the tC2s in the state with your foam!!!
