Camber Bolt Install (SPC)
*sigh*
The new guy just came out to tell me how bad my tires are going to wear at that setting. Too bad I couldn't deal with one of the regulars.
"its ok. Just set them to what I asked for."
So here's what I ended up with... (green is the new setting).
[table="head;width=400;"]LF Before|LF After|Setting|RF After|RF Before
-1.88*|-1.93*|Camber|-1.92*|-2.09*
3.40*|3.26*|Caster|3.29*|3.22*
0.91*|-0.02*|Toe|-0.03*|0.92*
[/table]
[table="head;width=400;"]LR Before|LR After|Setting|RR After|RR Before
-1.59*|-1.50*|Camber|-1.19*|-1.31*
0.27*|0.28*|Toe|0.20*|0.20*
[/table]
The guy wasn't really "new" .. but not one of the usuals I deal with. I rarely see this guy. The other guys know me and will help me out - they also know wtf I'm talking about.
Thoughts on that setup? I actually didn't want to go here for this first one but I wanted to get it done before the next event (this sunday). If necessary, I have another place lined up to make changes if I have to go again. They just couldn't get me in soon enough this time.
[/table]
[/table]
Ya, I was surprised how far off the front toe was. I just had an alignment a couple months ago too. Rear toe is right on the border of spec (upper limit is .25 I think). Not where I'd want it... but I'll just have to be sure to rotate.
Originally Posted by ack154
Don't care about the rear too much. It's neg camber in the front that helps with turn-in.
our rear suspension has passive toe (steering) control via rubber bushings based on centrifugal force. So it would be good to have toe and camber the same both sides back there.
The fronts look good so it gave another 0.30 degrees in the front.. Not bad, easier to use this than to have to remove both bolts like toyota does to adjust the front camber.
A little bit of negative camber up front will help with turning. Basically give you more grip - so the outside tire will be more flat on the surface of the road instead of rolling over on to its outside edge - thus having a larger contact patch and then more grip.
back from the dead i guess?...i just got 2 sets of the ingalls front camber bolts and pretty much install them the same way right?...but each set comes with 2 so upper and lower bolt on the struts right? and both tabs facing in for neg camber??
I believe you'd want the top tab in and the bottom out to get the best angle.
Hey guys bringing this back from the dead sorry.
I just got my camber bolts in from Dezod today. Need to get them installed and aligned before saturdays auto x event. All season I have been running on my stock camber and my Rs3s shoulders are almost dead.
Question were you guys able to pull -2 degrees in the front with only using the top mounting bolt? Or did you guys have to use the lower one as well? Picked this kit up http://www.dezod.com/pd_ingalls_engi...r_kittc_05.cfm
Comes with bolts for the top and the bottom. And if you did use the lower bolt hole as well did you point the arrow to the tire or to the engine? I know the top needs to be pointed to the engine for neg camber.
kleecker
Jan 2, 2015 08:09 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
