Full 3rd Brake Light DIY
Originally Posted by etli
Yes, you can make these yourself if you're so inclined using a prototyping board and your own components. The problem is, you have to be skilled at soldering. AND you have to come up with a way to secure the components to the proto board. Solder may look like metal but, depending on the solder you use, it doesn't have "much" physical strength in tension or compression. When you're trunk is bouncing down streets with big potholes, or just un-even pavement, you're really shaking the hell out of the solder joints. My understanding regarding most people who do automotive wiring is that they use physical connecters like quick-connects, and butt-crimps.
as for quick connects/butt splices, those are the least reliable connections known to man. nothing is more permanant/reliable than a soldered joint/wire. It can be proven very easily.
take apart any led factory or aftermarket led item and you will see it all soldered..
frustrated bump because this never made it to the tech section and took me forever to find.
Edit: it made it to the tech section, I was looking for third or lighting not 3rd.
alphabetical order ftl
edited my above post - sorry for the confusion.
It might be worth nothing that in place of the DIY kit, (at the moment, unavailable) one can pick up 2 stock TBL's off the PPC and have a nice bright TBL for a fraction of the cost of the competition.
Best of all you get to practice with your dremel, and pick the best cut to glue back together into your TBL.
I had been thinking of making a full length brake light when I found this write up. I took it one step further when I found a set of LED's that had a sequential turn signal function. The LED's that I used I got at Autozone, they are called "TailLitz LEDs" they are made by Alpena which is the same company that makes all those colored LED strips. These are them.
[IMG]
[/IMG]
After following the instructions here, and a bit of wiring this is what I ended up with. This video shows the 3rd brake light while I hit the lock button on the key fob which is the same as having the 4-way flashers on. Excuse the missing bezel, I was in the process of removing the Scion emblem from it.
[IMG]
[/IMG]After following the instructions here, and a bit of wiring this is what I ended up with. This video shows the 3rd brake light while I hit the lock button on the key fob which is the same as having the 4-way flashers on. Excuse the missing bezel, I was in the process of removing the Scion emblem from it.
The video doesn't work. At least not anymore. Actually the DIY and almost all the pictures on this thread don't work. It might just be me and my dumb work computer but just a heads up.
I would love to get a full TBL for my RS 3.0. I think it would look so much better with the 3.0 LED tails then the 1/3 lit TBL.
yea, i couldn't figure out why they would design it like that except to save some $
the left third portion of my lights went out so I gotta see what's going on. Blizz, I can shoot you some pics when I get around to them. It was a pretty easy DIY. PM me ur email
evolving_machine
Oct 21, 2023 01:16 PM
xBSciontist
Jun 18, 2019 03:06 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
