LED Swap (05-06 HVAC w/Circuit MOD)
Originally Posted by KINGxOFxSKA
Originally Posted by j.roc
Good job NOT cracking the clock LCD!
So how much would it cost me to have you do this to my car next?
I just made a small correction in my post. I realized this morning that I mistakenly (in my tired state) typed that wrong. I used 1/4 watt resistors. 1/16th Watt is the minimum size that can be used, but 1/8th is probably easier to find. The original post is now corrected.
Originally Posted by jmiller20874
Engifineer, you are my f***ing hero
I now have a project to do as soon as I get back from my honeymoon. This is some top notch work, you are a true professional.
You should be able to find all of these at Radio Shack or a similar store.
3 680 Ohm (Blue, Grey, Brown) resistors at least 1/16th watt, but 1/8th or 1/4 are easier to find.
3 220 Ohm (Red, Red, Brown) resistors same rating as above
1 - 1K ohm resistor
1- 560 Ohm resistor
Small hookup wire
Soldering Iron 20W
Small 60/40, 65/35 or similar solder
Small solder wick
Tweezers or needle nose
Small end cutters
Phillips screwdriver (#2 works well)
Needle nose (cover with a cloth) to remove dial
That should get you everything I think!
You could probably use 570 Ohm resistors without concern of overloading the supply, but the 680s looked great so I stuck with them.
Small hookup wire
Soldering Iron 20W
Small solder wick
Small end cutters
thank you!
Originally Posted by killer4605
Originally Posted by Rivulent
Just bought the resistors. 99 cents for a set of 5. I forgot hook up wire though, back I go
