tC Tech and DIY Info for the Scion tC
LED Swap (05-06 HVAC w/Circuit MOD)
Old Oct 15, 2006 | 07:39 AM
  #221
SquallLHeart's Avatar
whoa.. huh?!
okay... that's just WEIRD.... i dunno what's going on and if anything is normal and uh... i dunno if you just thought it wasn't.. uhm.... hmm...
yea.... crap.. next friday i take off for the weekend.... would have to be tues or thurs afternoon between 12pm and 5pm...
Old Oct 16, 2006 | 04:34 PM
  #222
whalentC's Avatar
Default resistors on the HVAC fix
no, I am not asking what impedance to use. I am asking if it is possible to use ceramic resistors, the ones you get a radioshack with axial leads on the front of the board. I know you used it on the back of the board, but the SMD resistors are used on the front. I am doing this mod this weekend (while my wife is out of town) and need to know if I can hit up the 'shack and be ok!
  #223
whalentC's Avatar
Old Oct 16, 2006 | 04:45 PM
  #224
IceNine's Avatar
yep, you'll be ok. But you'll have to cut up the plastic shrouds that surround the LED's after re-assembly... Ridiculous Shack only has enormous 1/2 or 1/4 watt resistors last I was there.
Old Oct 16, 2006 | 04:50 PM
  #225
whalentC's Avatar
awesome. thanks alot. I already did the gauge switch and HU switch. This weekend I will finish up the HVAC, steering wheel controls, and door switched.
** sorry about the double post
Old Oct 16, 2006 | 07:02 PM
  #226
DivisionbyZero's Avatar
Just a little note:
I've done 2 HVAC boards now, one with engifineer's kit and one without. I can't explain how much easier it was having all the pre-bent wires, I didn't even have to think about what I was doing. If you are thinking about changing the LED's on the HVAC, do yourself a favor and talk to engifineer first. It'll pay for itself in time saved (not to mention frustration avoided)
Old Oct 16, 2006 | 07:49 PM
  #227
whalentC's Avatar
Are the prebent wires just hook-up wires?
Old Oct 16, 2006 | 08:12 PM
  #228
engifineer's kit contained all the wires and resistors needed to modify the circuit. The resistors were all the right values and perfectly bent to fit. I was also able to pick up some LED's from him as well.
Old Oct 16, 2006 | 09:58 PM
  #229
V0RT3X's Avatar
No offense but how hard is it to bend a wire ? I dont know about u, but i use the really small wrapping wire at radio shack and you dont even have to bend those at all
Old Oct 16, 2006 | 10:14 PM
  #230
uhh... take wire... bend...?
resistors can be bought anywhere too...
Old Oct 29, 2006 | 07:22 AM
  #231
bump because people are.... yea....
Old Oct 29, 2006 | 04:31 PM
  #232
phiquach's Avatar
so, squall said i was missing a trace... what trace am i missing? i've looked at all the intructions and pictures... don't know what trace.
Old Oct 29, 2006 | 04:43 PM
  #233
engifineer's Avatar
I made the kits more as a response to those asking for something along those lines. I like using a little stiffer wire and running beneath the light surrounds to make it sturdy and keep everthing from vibrating around as much. I also send illustrated instructions with marked up pictures to make it a little easier. The idea for most that buy them is that they dont really have to worry about soldering to the wrong points by mistake as much. With everything cut to length and bent, you just have to cut the traces and solder everything in place. It is just less to worry about for those doing thier first electronics mod like this... and easier for those of us doing them over and over
But, this morning I built up a new kit, that works on all models and requires no cutting of traces and has much less work involved for installation. It is on my car and will be tested for a short while to make sure everything is ok. I am also adding some failure protection to it to reduce problems if something is not connected properly, parts fail or short for one reason or another, etc. As always, I dont want to sell anything that I havent finished testing thoroughly on my car first. So I will update soon :D
Old Oct 29, 2006 | 09:13 PM
  #234
between D310 and D316
and go dave.. waiting for an update..
Old Oct 29, 2006 | 09:41 PM
  #235
phiquach's Avatar
oh now i see, so i just cut it. alrighty thennnnn
Old Oct 29, 2006 | 11:17 PM
  #236
V0RT3X's Avatar
Look like you miss R307 too, take that resistor out and short that connection
Old Oct 29, 2006 | 11:24 PM
  #237
engifineer's Avatar
Yep, short R307, cut the trace coming into the left side of D316 and you should be in business
Old Oct 29, 2006 | 11:56 PM
  #238
ohh.. totally overlooked that.... eyah.. ^^ what they said..
Old Oct 31, 2006 | 06:36 PM
  #239
engifineer's Avatar
Testing looks great so far on my car. If all looks well through the weekend, I will do more of a stress test and order the final components to make them (the no cutting HVAC kit). I will then be able to start offering them. The other nice thing about it is that it build the foundation for another mod someone brought up for the lighting, so hopefully I can test that at the same time. I will update this weekend.
Old Nov 4, 2006 | 03:38 AM
  #240
all4degame's Avatar
How much would one of these new kits, along with all the LEDs needed for the guages + hvac, run for?
