tC Tech and DIY Info for the Scion tC
Turbo Install (ZPI Stage 0)
Old Apr 7, 2008 | 04:56 PM
  #221
Mr_Meaty's Avatar
...I was kinda shocked with your first response...was waiting on that second response! Thanks for not makeing me loose my faith in you, rhythm!
in any event, it doesn't matter. ZPI is dead and there is no reason to defend the company anymore. You can defend their products as much as we want as they are still in circulation as used kits, but the COMPANY is dead.
oh, and that new kit he put out with that new company looks super clean, don't it?
Old Apr 8, 2008 | 01:24 AM
  #222
rhythmnsmoke's Avatar
Music City Scions
You know me....I like to keep it as accurate as possible . People take things way out of context when they read them over the internet...
The "new kit" isn't really a "new kit" to my knowledge though. I thought they were for the most part "one-off" kits (nonetheless bad ___ though, running the Turbonetics GTK turbines). I think that's my next turbo. One capable of pumping 550-600whp.
Old Apr 9, 2008 | 06:26 PM
  #223
Troys_tc's Avatar
so that line you t-tap for the vacume lines is the one that comes off the TB and runs to that clicking block?
Old Apr 14, 2008 | 05:02 AM
  #224
Troys_tc's Avatar
I still need help with the vacume line setup, if any one could post some pic's of there setup that would be great
Old Apr 14, 2008 | 03:38 PM
  #225
Mr_Meaty's Avatar
the yellow circle on the right is one you could use...really good for yoru BOV.
The yellow circle on the left is where we all tapped our vacblocks into, so you can use that for WG and Boost Gauge.
Old Apr 15, 2008 | 03:23 AM
  #226
Troys_tc's Avatar
ok I'll try it out, are the vacume blocks worth using?
Old Apr 15, 2008 | 05:42 AM
  #227
Mr_Meaty's Avatar
yup...their great.
Old Apr 15, 2008 | 06:30 AM
  #228
Troys_tc's Avatar
do you have pics of one installed?
Old Apr 15, 2008 | 01:29 PM
  #229
Mr_Meaty's Avatar
a pic of what installed? a vacuum block?
um....yeah....I kinda just posted it....ya know...that big silver thing with all the tubes coming out of it an the big "TurboToyotas" logo on it?.....
Old Apr 15, 2008 | 02:17 PM
  #230
Troys_tc's Avatar
no, a picture showing how the lines are ran to it, like a top view
Old Apr 15, 2008 | 03:20 PM
  #231
Mr_Meaty's Avatar
Well, in that top pic, the line on the bottom left is going to my WG...the middle to my Boost Gauge and the bottom right going to my BOV.
In the following pic, the arrow is showing the line coming off the right that goes into that yellow circle.
The left side of my vac block is going to the other end of the left yellow circle in the first pic:
Old Apr 15, 2008 | 03:21 PM
  #232
Mr_Meaty's Avatar
Basically, the vac block is teed into the break booster line (left circle in first pic, on the firewall with the hard line) and acts as 3 Tees for all your vac line needs.
Old Apr 15, 2008 | 04:06 PM
  #233
Music City Scions
I was kinda going to say the same thing.
Old Apr 18, 2008 | 01:21 AM
  #234
Troys_tc's Avatar
but doesnt the wastegate need a vacume port pre- tb, and the bov needs one post tb
Old Apr 18, 2008 | 03:11 AM
  #235
Mr_Meaty's Avatar
um...i dont' think so. vacume is vacume, right?
Old Apr 18, 2008 | 03:15 PM
  #236
Troys_tc's Avatar
well from what I have heard from all my friedns runging sr20 powered 240's, they siad you need differnt vacume ref points because the of what the parts are doing, the waste gate is only used when your at you correct bar psi, and the bov is only used when the throttle is closed
Old Apr 29, 2008 | 03:33 AM
  #237
Troys_tc's Avatar
what is the most boost you can safley run on the stock ecu and injectors?
Old Apr 29, 2008 | 04:55 AM
  #238
tCtCtC's Avatar
no where past 6.
(it should be none at all)
Old Apr 29, 2008 | 06:58 AM
  #239
Mr_Meaty's Avatar
My vote is for 0psi.
It's really not a good idea to run a turbo kit with stock ECU, stock injectors and no IC.
Alot of the ZPI Stage 0 Guys ened up getting all those items eventually...
Old Apr 29, 2008 | 03:05 PM
  #240
Troys_tc's Avatar
what about if I am only planning on running race gas?
