xA Tech and DIY Info for the Scion xA
Ground Wire Kit Install (Homemade)
Old Jul 31, 2006 | 06:20 PM
  #201
jon-w9's Avatar
I couldn't tell with mine. I almost think it idles a bit rougher.
At a stoplight it sits fine for a bit, then it begins to idle really rough. I think it may have to do with the AC compressor kicking in, but I haven't turned it off since it has been so dang hot. It goes away if i go to Neutral or Park.
Old Aug 1, 2006 | 03:20 AM
  #202
designed24's Avatar
Yeah, I would have to agree with you... my idle was bad before now its all over the place. from 400-1500 rpm. weird.
Old Aug 11, 2006 | 03:49 AM
  #203
uber-xA-RS2's Avatar
Ground Wire Kit success!
I finally installed my Mikochu uber Ground Wires today and it has made a big difference in the idle, it's now nice a smooth. Also my stereo is a bit crisper. I'm still waiting to see what it does for the lighting but a big thumbs up for Mikochu on this one!
Old Aug 23, 2006 | 03:50 AM
  #204
Taugenichts's Avatar
So... what is a typical idle. Shouldn't most of the xA's/B's idle at around the same range? Mine has never gone so low as 400 even with no a/c, etc, running. 800/900 is pretty much what I consider my "low" idle"... 1300-1500 being the higher and more typical.
Old Aug 25, 2006 | 07:26 PM
  #205
Blacklisted's Avatar
wow i just installed mine last night on my auto xB and all i can say is
"did i just shift? cuz the tach said i shifted but i didnt feel it... hmm..."
two thumbs way up!
Old Sep 2, 2006 | 11:07 PM
  #206
Chops's Avatar
I installed mine yesterday:
And was I surprised at how well it worked (not that I didn't trust you Mikochu), but my idle seems to be lower, like around 500 instead of 1000 and when my car shifts gears, it's a lot smoother. Not sure about the audio bonus some have claimed or the static... but it does seem to have helped.
And also waiting to see about the lights as well.
Old Sep 3, 2006 | 12:44 AM
  #207
fokusco's Avatar
StyleWagons
WEEEE! A project for next weekend! hahaha
Old Sep 9, 2006 | 12:02 AM
  #208
Astrofuse's Avatar
Installed the Kit last nite! Thx Mikochu!!! I used Black High Heat 6gauge wire throughout with black heatshrink (so OEM). Cold idle is now @800rpm warm idle is @500 rpm New OBX header dropped my idle to @500 rpm and i love it. Thx again Mikochu for the awesome DIY and pics keep it up. Next...ground the girls new tC...
Old Sep 11, 2006 | 12:07 PM
  #209
fokusco's Avatar
StyleWagons
I did mine this weekend! WOW it does not feel like my car is shifting at all... That is pure madness... Is it just me or is it possible for hid's to be brighter due to this kit?
Old Sep 12, 2006 | 01:50 AM
  #210
mikochu's Avatar
:D
Old Sep 14, 2006 | 07:27 AM
  #211
Astrofuse's Avatar
Just built and installed a 7-point ground kit in my fiancee's '07 automatic tC. Kit took me an hour or so to build, install took about 40 minutes. I used these points to ground: body-head, body-block, body-alternator, head-coil pack 4,coil pack 4-battery ground, battery negative-body, transmission-body. We used 10.5' of Black 6gauge high-temp wire, with black heatshrink for an OEM look. Much better throttle response, stronger idle, no shudder when you start the car with the AC blowing, more stereo clarity...she loves it...and is convinced the shifts are smoother too, even at higher Rpm. All at a total cost of less than $40.00! Will post pics soon.
Old Oct 2, 2006 | 04:12 PM
  #212
abdielhiram's Avatar
I have installed Mine Yesterday.
Things Changed immediately.
Better Idle, Better Lightning and Awesome Sound. Also the Car seems more powerful on the 3rd. Shift.
Thank´s for the Hint.
Old Oct 4, 2006 | 11:34 PM
  #213
kuro-xb's Avatar
Installed mine last week using my old grounding kit. Improved normal and A/C idle a little. Can't go with free stuff!!!
Old Oct 9, 2006 | 09:34 PM
  #214
itsmistale2u's Avatar
has anyone here used the ground kits from ebay? lmk what ya'll think?
Old Oct 12, 2006 | 08:28 PM
  #215
Breadbox_Boy's Avatar
yo itsmistale2u, I got a cheap-o ($20) grounding kit from e-bay. Similar to this one (http://cgi.ebay.com/ebaymotors/04-05...spagenameZWDVW)
Following the instructions here on SL, it was super -easy to hook up.. did it make much of a difference? Ehhh, some days I think it did, some days I can't tell. I left the wires on just cause they mess with people (like at Jiffy Lube) that open the hood. "What are these tube things?" "Oh, those are for the freon cooled super charger.. bump them loose and the freon will freeze your arm off." Funny how that makes them real careful working on your box. I know, it's not nice to screw with people like that... but damn, it sure is fun.
Old Dec 1, 2006 | 05:58 AM
  #216
Hoshizaki's Avatar
Did it. Home Depot 8 gauge, w/ring connectors from The Specialist, heat shrink from Radio Shack. I like this mod. Low cost, easy install.
Old Dec 5, 2006 | 02:39 AM
  #217
sotx_scion's Avatar
awsome how-to. If not for members like you most of us would be lost!!! Thanks again!
Old Dec 20, 2006 | 02:49 AM
  #218
dmpsk8's Avatar
i did mine w/ 4 gauge and it made a big diff, plus it looks hella sweet
Old Feb 2, 2007 | 09:50 PM
  #219
KobraKommanderVA's Avatar
Somebody needs to do a detailed walkthrough On the TC!!! puh-leeez
Old Feb 5, 2007 | 12:35 PM
  #220
oldmanatee's Avatar
It can't be that different on a tC... just use string to measure your wire lengths...go from body to block, block to #4 plug (or daisy chain all 4 plugs if you want), #4 to battery neg., neg to body...
