xA Tech and DIY Info for the Scion xA
Ground Wire Kit Install (Homemade)
Old Oct 30, 2007 | 06:42 AM
  #301
Amoxaphobic's Avatar
Originally Posted by cobb
Originally Posted by Matt_Burgess
You don't put the ground on the positive/hot wire of the alternator. You put the ground onto the body of the alternator.
Anyone up for :grounding" the battery?
I realize this - I am not a complete idiot when it comes to electrical. I guess I should have been more specific with my question.
On of the main reasons for the alternator is to recharge your system. Thus the alternator creates a flow of electrons which in turn would create an electro-magnetic field. Grounding the shell or body of the alternator may have some effect on this, and that was more where my question was going. However, the following response on how the grounding actually helps cleared things up a bit for me.
Thanks.
Old Oct 30, 2007 | 06:47 AM
  #302
jiggadomino's Avatar
yea i guess its ok to ground the alternator, but not the wires that connect it to the battery...
goodluck finding a place on the alternator to attach your grounding wires (besides the wires that lead to the battery)
Old Oct 30, 2007 | 09:21 PM
  #303
Matt_Burgess's Avatar
There is a bolt right on top.. It's a bolt that holds a bracket for a wire loome. I just put my ground wire between the body of the alternator and the bracket and put the bolt back in.
Old Nov 13, 2007 | 12:15 AM
  #304
rhin0sb's Avatar
i can't find 8 guage ring connectors anywhere by my house.
when i picked up the speaker wire for the kit, the guy gave me a couple 12-10 guage ring connectors. the hole for the ring is 5/16th and the when i stripped the 8 guage wire and twisted it up, it fits into the 12-10 guage ring connector fine. there's no real extra space in the crimp part. so i could just use 10-12 guage ring connectors?
also the ring connectors come with some yellow insulation. is that heat shrink?
thanks in advance, i'm excited to do this.
Old Nov 13, 2007 | 01:20 AM
  #305
thanks mista burgess!
Old Dec 18, 2007 | 08:23 PM
  #306
Nastos's Avatar
can some one please tell me where to pick up this alleged 8 ga. wire? ive been everywhere Lowes, Home Depot, Local Hardware, walmart, Aco random home audio video places, radio shack.. am i asking for the wrong thing when i say 8 gauge speaker wire? no one has it or any 8 gauge ring connectors please let me know....
Old Dec 18, 2007 | 09:30 PM
  #307
Go with 4 gauge wire. Try ebay there pretty cheap, get like 20 feet of it. Here you go,
http://cgi.ebay.com/20-FT-4-GAUGE-BL...QQcmdZViewItem
Old Dec 18, 2007 | 10:57 PM
  #308
tC-Collin's Avatar
Scion Tuners
lol sorry, but in that link is says this wire is "FLEXABLE LIKE A WET NOODLE"
Old Dec 18, 2007 | 11:14 PM
  #309
Lol, yea i just read that lol funny
Old Dec 19, 2007 | 09:37 PM
  #310
Nastos's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=018
i got 10 feet of that... is that good? also these
the connectors come with free tweeters? what am i supposed to do with those
Old Jan 12, 2008 | 07:37 PM
  #311
That wire should do the trick.
Old Feb 17, 2008 | 06:44 AM
  #312
CSOCSO's Avatar
just finished installing the TRD-ebay grounding kit
well.. it wasnt easy because i couldnt use the supplied installation kit!!!! i dont know how could i install this kit with a different battery!!!!
but i was lucky because i was able to nstall it somehow else so here is my grounding points:
negative terminal - right body
negative terminal - coil
negative terminal - head
negative terminal - alternator
alternator - left body
pictures: ( if they dont work u haw to wait a little bit... come back 1-2 hours later.. but any input is welcome.. so pls come back and reply!!) [ LOOOL you haw to wait :D i had to leave that misspelling in there .. its so funny D:D:D my english is ROX! ]
right body
coil
left body ( from alternator)
alternator [cable 1 is coming from battery - cable 2 is going to left body ]
head ( two pictures)
did i connect everything to the right place?????????????????????
connect only 1 coil is fine? should i conect the other one?
connecting only the left side of the head is fine? should i connect the right side also?
i connected the alternator to the right screw.. right?
i didnt connect my trans because im manual... but how could i connect it to the intake manifold?
pls reply asap!!!! i didnt started my car yet.. so i hope im gonna get some input before i wake up tomorrow....
Old Feb 17, 2008 | 03:14 PM
  #313
TomsTC85's Avatar
I bought that setup also, and with the stock battery I have to figure out a way to mod it so that the POS install kit will work. I will prob have to just use the wires and not the plate, and just mount it somewhere just for show or something. My engine bay looks very similar, but I think I will use the mounting points from the other DIY.
Old Feb 17, 2008 | 04:59 PM
  #314
CSOCSO's Avatar
so.. i started the car today.. of course the idle was horrible for like 10 minutes so i decided to drive around for a few minutes.. after like 10 minutes i stopped at the stop sign and the idle was good now..
so i went home.. stopped at the house for a 5-10 mintes inspection
i think the idle is a slightly better.. its still mover around a lil bit but i think not that much...
when i turn on the A/C the car is not shaking that much.. so its a little bit better...
when i start the car is the same i think. but my bro told me hes car starts just the same ( hes got an 08 w/o mods)
so hurray... but i will see when i drive around a lot..
Old Mar 9, 2008 | 09:08 AM
  #315
HondAudio's Avatar
I have some ground wires in there that a guy gave me for free, but I will be redoing them shortly. I have some 8-AWG Streetwires black cable from back in the day, some black braided loom wire cover, heatshrink, and gold ring terminals. I picked up a heatgun yesterday. Just gotta get started
Old Mar 9, 2008 | 09:51 AM
  #316
curtislo9's Avatar
CSOCSO can you fix your pictures. I want to do this and model it after yours. You think it is a good mod?
Old Mar 12, 2008 | 06:50 AM
  #317
HondAudio's Avatar
Anybody want the old wires I took out? Free in Phoenix.
Old Mar 13, 2008 | 08:23 AM
  #318
agentorunge's Avatar
already ordered the parts from knukonceptz. are the grounding parts different between a manual or auto xb1? do we ground it to the neg battery terminal or the stock ground point from the battery on the frame near the headlight?
Old Mar 30, 2008 | 06:38 AM
  #319
ANightDriver's Avatar
Default Re: Ground Wire Kit DIY/Install
I did this mainly to help preventing static shock when getting out of the car per the OP. And it helped for a while, but then the shock has returned. Then I went to a diler to change my oil and noticed that the shock has gone after that. I opened the hood and a miracle all the wire terminals were painted with some pink color. It would be nice to know what that paint was.
Old Mar 30, 2008 | 10:38 PM
  #320
HondAudio's Avatar
I don't have any 'installed' pics, but here's what the ends of my cables look like:
