xB Tech and DIY Info for the Scion xB
A/C Control Color Change
Old Aug 16, 2006 | 03:39 PM
  #201
D_M_A_N's Avatar
Sweeeet! I thought that might be possible, Nice job!
Did you do the LED's in your HU yourself?
Also whats inside your AC Vents LED's or Cathode?
Old Aug 16, 2006 | 03:50 PM
  #202
Blue_Estel's Avatar
Thanks.
Yes, I did the HU myself... not to "toot my own horn" but I was the first one to do the LED swap on the head unit... I just dragged "butt" on getting a DIY out there... I'm not very good at write-ups.
The vents are all LED's also purchased from Oznium.com.
Here's a link to my gallery at se-detroit.com, please feel free to check out some of the many LED mods I've done to my xA and shoot me a PM if you have any questions.
http://se-detroit.com/gallery/thumbnails.php?album=10
Old Aug 16, 2006 | 06:25 PM
  #203
DiStUrBeD_AzN's Avatar
Unique Scionikz
Thanks.
Wow, there's a DIY on the HU too? I can't seem to find it.
How difficult was it to find a location to mount the cathodes in the A/C Controls? Can you turn it on/off? Also, how did you get the LEDs in the AC Vent?
Old Aug 16, 2006 | 07:12 PM
  #204
D_M_A_N's Avatar
ok, you aren't looking hard enough
Here is how you use the "look around the website" feature. haha
go to "features" at the very top of this page
go to "tech"
filter to the xB
go to "radio color change"
the pics aren't working for some reason. I'll PM the guy who wrote it.
Old Aug 16, 2006 | 10:25 PM
  #205
mattmcl's Avatar
Hey Blue_Estel, would you mind posting a pic of how you mounted the tubes into the dash, behind the AC controls? Thanks, great idea.
Old Aug 17, 2006 | 04:01 AM
  #206
peteski's Avatar
Nice mod Blue_Estel!
I'm doing my HU now. That thing has a crapload if 0603 LEDs in it! What a pain. My plan is to wire in RGB LED under the "color" button, so that it changes color with the display. This is the new iPod unit.
Also, my LED A/C mod illuminates pretty evenly. Looks good to me. I also put white LEDs in the clock/odometer display (xB).
I'll post a picture once everything is finished.
Old Aug 17, 2006 | 04:54 AM
  #207
hcsif's Avatar
this is awesome how to do you guys get to the inside of the headunit to where the LED;s are?
Old Aug 17, 2006 | 10:26 PM
  #208
dmpsk8's Avatar
EVERYONE READ FOR EASIEST METHOD WITH GOOD RESULTS
go to ur local pep boys and pick up a 3 pack of "PIOLET LED Anywhere" LEDs for about 5 bucks. i suggest u get a few packs n some nice switches cuz these things r addictive and way too easy. they come with snap in holders and are ALREADY WIRIED W/ RESISTORS. now as stated awhile back u can tap into the brite white wiring harness for ur power n ground connections. green wire=power and white w/ blk stripe=negative. these particular LED's snap-in holders are a 100% PERFECT FIT in the hole where the lamp plugs in. so pop in ur holders insert the LEDs and run the wires into the harness. i that easy. i suggest u sand the tips of the LEDS with sand paper for an even glow, this was also stated on page 5 i think. you may want to run some other LEDS while ur in there too. i did the controls, the oven, and my AC vents. looks sick and only took bout 45 min to do everything.
Or u could wait 2 weeks n order leds form japan, or bust plastic wedge tips off, or attempt to fight with miniscule resistors to save $1.50...i thats ur thing...
Old Aug 18, 2006 | 01:08 AM
  #209
peteski's Avatar
Pull the radio out. There are 2 screws on the sides of the faceplate - remove them. Then release all the faceplate tabs (all around). Faceplate pulls right off the radio. Then you need to unscrew 8 screws with white arrows pointing to them. Don't mix them up as some are different. Those 8 hold the green circuit board. Pull up the circuit board. All the LEDs are solderd to the circuit board.
Old Aug 22, 2006 | 10:20 PM
  #210
blomy_bx's Avatar
i found these condom caps for mine on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...category=48696
Old Aug 26, 2006 | 07:08 AM
  #211
peteski's Avatar
Here's my dashboard mod. I used white LEDS for backlighting everything, with some color sprinkled on the radio faceplate. I also used an RGB LED under the radio's "COLOR" button and I wired it into the display backlight circuit. So the "COLOR" button's backlight changes color with the display. I also left the warning lights in the original colors, so they stand out better from the backlighting when they illuminate.
Old Aug 29, 2006 | 08:08 AM
  #212
Gsnorgathon's Avatar
Too sweet (almost) for words.
I'd love the details on how you did the A/C fresh air/recycle lever. That one's been bugging me. Given my experience and skills (i.e., lack of), I'd love to see how it's done by someone who actually knows what they're doing.
Old Aug 30, 2006 | 03:48 AM
  #213
peteski's Avatar
Thanks!
As far as that silly lever goes, it was bugging me too. Originally I thought I could just cut a slit in it and put in a piece of clear acrylic in it as a light "pipe". I was planning on just pointing it down towards the fully illiminated center cavity. But there is a big dvider between where the lever is and the bottom illuminated cavity. So, that wasn't going to fly.
But I still drilled through the lever and using a very small jigsaw I cut the slit. On the inside I drilled a hole into the slit to accomodate a white T1 size LED. I then put in a piece of 1/16" thick acrylic inn as a light "pipe" then at the visible (outside) end I glued in a strip of .0.20" white styrene (to diffuse the light). Since the lever handle is hollow I had to glue pieces of black styrene on the bottom to prevent light from scattering down.
I then uses a dollhouse zip-cord (very fine 2-conductor flexible wire) to hook it up. I drilled through the lever's pivot point and threaded the wire through the hole. Then I ran it to the blower switch assy. That is where my other white LEDs are installed. I did put a in-line connector in case I have to take the dash apart again.
This mod was a bit of a pain but I think it was worth it.
Old Aug 30, 2006 | 08:43 PM
  #214
Wow. Thanks for all the details - I was afraid you were going to say something like that... guess I'd better just swallow hard, get my materials together, and get to it.
Old Sep 3, 2006 | 02:24 AM
  #215
vxgasattack's Avatar
I used bulv condoms to make my climate controls blue, but after seeing some of the above pics I may just have to go and spend a little more time!!!
Old Sep 5, 2006 | 02:02 PM
  #216
bb20inches's Avatar
looks good man good post i think bright led would be cool but more money and work..
Old Sep 11, 2006 | 04:45 AM
  #217
onionescion's Avatar
I like GREAT JOB
Old Sep 13, 2006 | 04:12 AM
  #218
carefreetoast4's Avatar
Default replacement bulbs
Check out this site: http://autolumination.com/74.htm. Scroll about half way down. These bulbs seem to be a direct replacment for the ones installed at the factory. I ordered some the other day and I am just waiting for them to get here. Should only be a day or two. I will post again with my results and hopefully a pic or two.
Old Sep 13, 2006 | 03:14 PM
  #219
LeroyJMC's Avatar
hey carefreetoast4, please let us know if the ones from that site work. I deffinitely need something brighter than my bulb covers.
Old Sep 15, 2006 | 02:10 AM
  #220
scooterxb's Avatar
It would be cool of you could wire rgb leds into the ac controls so that when you changed the radio color, all the leds would change.
