TB Bypass Kit
Found this online, and was wondering if any of you guys have done it.
6-8 HP for like $15?
http://www.gofastperformance.com/pro...oducts_id=5117
I don't know if it actually works, but I personally wouldn't do it because it might void the warranty... and 4-8 hp is not worth voiding the warranty.
Also, you get what you pay for. It might be more of a burden than a good thing in the long run.
But I got to tell you, that when I first saw the topic title, I thought of the bad TB infection starting... a bypass kit for that... woot!
Originally Posted by MyblackTC
Dear god, these are still around? For a time, this was "THE" thing to do to the older GM 2.8/3.1L V6s. The theory behind this is that by removing the "hot coolant" from the small passage in the throttle body, intake air temperatures will be reduced. If that nets 1 HP, I'd be surprised. If the above setup nets 6-9, I'll run across the country doused in corn syrup wearing nothing but shoes and a Nixon mask.
Has anyone ever seen the amount of coolant that passes through the throttle body on a 2AZ-FE? On the GM V6's, you'd be lucky to get half of a shot glass from the coolant passage. All the coolant is there to do is provide a small measure of heat when the engine is cold, similar to what a choke's thermostat would do on a carbureted engine.
My $.02 on this "mod": If you have the engine out for any reasons, buy a $.50 piece of hose, make a loop to the two passages and cap it off. It's not even worth the time messing with it, since the gains will be miniscule, if there are any at all.
stillcole
Scion tC 2G ICE & Interior
Apr 6, 2015 03:42 PM
clickclickw00t
Feb 18, 2015 08:57 PM
armyrockmorales
Dec 28, 2014 10:39 PM
