Strange Noise Sounds Like An Old VW Bus/Bug
Old Jul 22, 2007 | 07:20 PM
Alienink's Avatar
Default Strange Noise Sounds Like An Old VW Bus/Bug
Hello!
As the topic says, my box makes a strange noise when accelerating from 0-25mph.
It sounds like an old Volkswagon bus engine.
Im sure it is just a part but I dont know much about under the hood.
any insight would be great!
Thanks,
-Kevin
Old Jul 22, 2007 | 11:12 PM
frogbox's Avatar
I see you added an exhaust to your car , take a look at the gasket/donut , does it happen to be bad?
Old Jul 22, 2007 | 11:47 PM
hotbox05's Avatar
a vw sound would promt me to think a bad exhaust manifold to down pipe gasket.
Old Jul 23, 2007 | 12:06 AM
bB2NER's Avatar
Music City Scions
Sounds like the rear gasket has gone bad. I had to replace mine when I added the Strup axleback. They are like 10 bucks or so at the dealer.
Old Jul 23, 2007 | 01:35 AM
Alienink's Avatar
Wow, thanks for the quick responses. Where is the gasket??
I appreciate the help!
I will def look into the exhaust.
Thanks guys!
Old Jul 23, 2007 | 01:49 AM
bB2NER's Avatar
Music City Scions
It's located between the rear section and the rest of the exhaust. After several exhaust changes mine just fell apart. You only need to remove the clamp. Pull the pipes apart. Slip on the new gasket and reassemble. When the gasket is bad it will leak and allow the muffler assembly to move around and sometimes get too close to the bumper opening and melt the hole. Center the tip in the opening before final tightening of the clamp.
No problem on the quick response That is why we are here. To help fellow Scion Nuts.
Old Jul 23, 2007 | 01:54 AM
frogbox's Avatar
Thanks guys!
easiest way is to open your hood, start the car and listen for the noise ( getting a buddy to help is great).
one gasket is between the head and header ( exhaust manifold), second is where the header connects to the pipe w/cat converter,resonator, the third ( which is one that maybe the problem ) is just over the rear axel ( when you added the new exhaust this is the most likely one to get damaged )
hope this helps
Old Jul 23, 2007 | 02:08 AM
Alienink's Avatar
thanks! I will check it out this week and get back to the post!
-Kevin
Old Jul 23, 2007 | 05:27 AM
OldYeller's Avatar
There are worse things than sounding like a Vdub........LOL
Old Jul 23, 2007 | 11:02 AM
bB2NER's Avatar
Music City Scions
Yes, but not when driving an xB!
Old Dec 31, 2007 | 03:26 AM
Alienink's Avatar
I brought the car in a few months ago. They replaced a "doughnut" in the exhaust. So far it has sounded better than what it was. Thanks for the advice everyone!
baker08tc
Apr 9, 2015 09:47 PM
evolving_machine
Feb 27, 2015 09:53 PM
brownSys
Feb 27, 2015 04:20 PM
corbmonster
Jan 24, 2015 05:22 PM
evolving_machine
Jan 13, 2015 08:04 PM
