Got a nail in my tire...
Old Aug 15, 2007 | 10:26 PM
Archngl's Avatar
Default Got a nail in my tire...
It seems to be all the way into my tire... but no air is leaking out... what do i do?
Old Aug 15, 2007 | 10:49 PM
littleball11101's Avatar
take it to a tire shop. 10-20$
Old Aug 15, 2007 | 10:51 PM
Archngl's Avatar
That sounds insightful and inexpensive.
You win!
Old Aug 15, 2007 | 11:31 PM
evosky's Avatar
yeah. i had a nail in my tire a couple days ago. took it to the local goodyear. they charged me 22 bucks to remove the nail and plug it.
Old Aug 15, 2007 | 11:33 PM
jdmtoybb's Avatar
Old Aug 15, 2007 | 11:34 PM
Big_Bird's Avatar
word, had the same thing with one of my steelies, $15 under the table, good as new
Old Aug 16, 2007 | 12:16 AM
TerribleTed's Avatar
With a radial tire it is not advisable to plug the hole. The tire should be dismounted and the hole properly patched from the inside. If the hole is within about 1" of the side of the tire the tire should be replaced not repaired. Plugs inserted from the outside of a radial tire tend to get cut off by the belts over time causing the tire to go flat again, an internal patch does not have this tendency.
Old Aug 16, 2007 | 12:20 AM
ryuji16's Avatar
be careful where you take it... ive had rims scratched while they removed the tires. they werent careful and the machine scrubbed the outside of the lip. if you have expensive rims, take it to a more reputable shop
Old Aug 16, 2007 | 12:24 AM
PakanaHerruus's Avatar
same thing happened to me.. they didnt charge me anything.. and put it back on the car.. they said "its, cool we like you guys at Hawaii Racing".. lol sweet..
Old Aug 17, 2007 | 01:44 AM
bigshrek's Avatar
take the nail out and put green goop in it
Old Aug 17, 2007 | 04:21 AM
NOT a good idea. Tire sealants are dangerous.....some are explosive....some can cause the inside of the tire to deteriorate,....most all cause the tire to be out of balance. They can also cause clogging of the valve stem (the next time you put air in the valve may not seal due to 1/2 dryed goop in it). A proper tire inside patch repair is not that expensive $20ish and is well worth it. If the tire is old spend a few more dollars and simply replace it.
When I buy tires most places have a roadhazard warrantee for a reasonable price (this pays for any flat repairs...as well as a replacement tires if the tire is damaged beyond repair). On my current 18's the road hazard cost me $10 per tire. So if over the life of the tire I get 2 flat tires on my set of 4 I broke even. Hmmm let me see...so far in 8k miles I have had 1 flat repair a screw, 1 flat tire a nail (this one was right next to the sidewall so they replaced the tire...when they do this you generally have to re-pay the road hazard warrantee, so I paid $10 that time and got a new tire). So for $50 for road hazard on 5 tires (including the replacement) I got a $20 flat repair and a $165 tire...not a bad deal!!...and I am still covered for road hazard on all 4 tires for the life of the tread. (note they do prorate replacements under these warrantees...usually after %50 wear...still better than full price if you have a failure, or hit a curb or whatever).
ScionDP
Scion tC 2G ICE & Interior
Nov 5, 2015 09:59 AM
bcharley3
21
Apr 6, 2005 12:58 PM
ROBUPNYA
12
Mar 15, 2005 05:18 PM
herbie_the_luvbox
Mar 6, 2005 03:43 AM
scionscorpion
Regional - Northeast
Feb 11, 2005 08:57 PM
