need help with tire size!!!
Old Sep 7, 2007 | 05:52 AM
Toast3rOv3n's Avatar
Default need help with tire size!!!
I didn't see my size covered in the fitment section
I have a set of GT20's (fake Equip) 16x7.5 et38 going on 06 xB ,,I'm going to lowered it a little bit for the nopishow ,but this is my wifes DD
thanks in advance guys ,,,,,ohh yeah what are you guys doing about the front rim rubbung the brake caliper ,,I thought about grinding the back side of the wheel
I'm counting on you guys to point me in the right direction
you guys like the color???going on white xB
Old Sep 7, 2007 | 07:29 AM
help...please!!!
Old Sep 7, 2007 | 02:09 PM
I know one of you have put these on your xB...help me out!!!
Old Sep 7, 2007 | 10:21 PM
sdsnybny's Avatar
Default dont grind
don't grind the wheel you may throw it off balance or weaken its integrity
some have ground the caliber or you could use a small spacer say 5mm in front.
nice color are those drag's wheels haven't heard of them before.
Old Sep 7, 2007 | 11:18 PM
yep they are DRAGs ....anyone on the TIRE SIZE?????
Old Sep 8, 2007 | 12:02 PM
I searched around and most tire distributers say you 215-40-16...but they cost to much....any ideas on a cheaper size???
Old Sep 8, 2007 | 02:54 PM
ttt....c'mon help me out
Old Sep 8, 2007 | 02:59 PM
813_toaster's Avatar
KAD
id go with like a 205 or 215 for width and a 45 or 50 for side wall
Old Sep 8, 2007 | 03:13 PM
BATComm1's Avatar
I just went with a 205/50/16 on my 16x8 rims..no problems in the front, but on the rear I had to do a little mod to the trailing arm..just a bit of trimming or if I had some 5 or 10 mm shims everything would would have been fine.
Old Sep 8, 2007 | 10:57 PM
you think if i went with 205-50-16 on 7½'s i'd have that trailing arm problem???
and also is 205-50-16 apprx the same hieth is the oem tires ,i dont wanna mess up the speedo to much?
Thanks
Old Sep 9, 2007 | 01:25 AM
sdsnybny's Avatar
215/45/16 -- 1/2% faster (smaller dia) closest to stock
205/45/16-- 2 1/2% faster """ '''''
if you go bigger than stock diameter 205/50/16 your speedo will be off even more than it is from dealer @3mph a faster tire (smaller dia) will help correct this and give more clearance when lowered this calculator is pretty helpful.
http://www.1010tires.com/TireSizeCalculator.asp
Old Sep 9, 2007 | 01:32 AM
sdsnybny's Avatar
you shouldnt have any rubbing on the back at all my 17x8 +40 barely rubbed yours are lower offset and not as wide = more clearance
Old Sep 9, 2007 | 08:59 AM
bB2NER's Avatar
Music City Scions
Stick with 205/50/16's and you will be fine. Have fun at NOPI. I did it 3 years ago with my toaster and had a blast. Looking forward to doing it again next year.
Old Sep 10, 2007 | 06:44 PM
yeah guy I got a buddy that work at Maxxis Tires ,,,and I might paint my orange wheels and get free tire....I'll give it a try anyways
but yeah i'm going to get the 205-60-16
Old Sep 10, 2007 | 06:50 PM
mike51392's Avatar
on the wheels you should have left the lip chrome
Old Sep 10, 2007 | 06:58 PM
bB2NER's Avatar
Music City Scions
Sorry but 205/60/16s will not fit. They are 2 inches taller than OE size and will rub in many places. Not to mention it will throw off your speedo and change your final gearing. 205/50/16 is less than 1/2 inch taller and will work fine.
http://www.rims-n-tires.com/rt_specs.jsp?postId=906
Old Sep 10, 2007 | 11:25 PM
dude...your totally right ,I mis-typed or I'm dyslexic...either way
I AM GOING WITH 205-50-16
thanks guys!!!!
Old Sep 11, 2007 | 06:54 AM
bB2NER's Avatar
Music City Scions
no problem
Please post up pics of the finished product.
evolving_machine
Scion xB 2nd-Gen Wheel & Tire
12
Jan 18, 2016 08:41 PM
scionlife
371
Jun 2, 2015 11:00 PM
kingofthecrate
Jan 21, 2015 09:28 PM
debris
Dec 16, 2003 11:50 PM
BUzzBUcket
10
Oct 12, 2003 07:19 PM
