ECU?
Old Nov 15, 2007 | 02:19 AM
fairladyz541's Avatar
Team Sushi
Default ECU?
Dose anyone have an ECU wire layout?
Need to know where a couple of wires are for my AFC Neo.............
Old Nov 15, 2007 | 01:02 PM
lastlookcustoms's Avatar
Which wires are you looking for and I can tell you...
Old Nov 15, 2007 | 03:27 PM
Team Sushi
2 ecu power leads
RPM signal
Throttle signal
2 ecu grounds
Airflow and pressure signal output
Illumination Power (the wire that illuminates the radio)
Old Nov 15, 2007 | 03:53 PM
give me some time. I will run to the shop in a few and get my layout.
Old Nov 15, 2007 | 05:48 PM
Team Sushi
Thank You
Old Nov 16, 2007 | 07:38 PM
Originally Posted by fairladyz541
2 ecu power leads
RPM signal
Throttle signal
2 ecu grounds
ecu power lead - Black wire terminal A28
RPM Signal - White terminal B122
Throttle Signal - Light Green terminal B115
2 ECU Grounds - White/Black stripe terminals B44 & B46
Airflow input - Violet terminal B118
Terminal A is the smaller connector and Terminal B is the larger connector
Terminals are numbered left to right, top to bottom as if you were holding the connector and looking at the end that plugs into the ECU
Old Nov 16, 2007 | 09:00 PM
Team Sushi
Thank You so much.............
Old Feb 12, 2008 | 10:00 AM
crush02342002's Avatar
I got a dumb question, since the second gen xb has the same engine as the tc are the computers the same and if so the pin outs should be the same right.
Old Feb 12, 2008 | 01:52 PM
AAG's Avatar
AAG
DeepSouth Scions
No they aren't the same ECUs
Old Feb 12, 2008 | 08:20 PM
thanks for the info
Old Feb 13, 2008 | 04:44 PM
jthistle's Avatar
Fairladyz541 let us know how your install goes and what gains you get from the AFC. I am very interested in this mod.
drgonzo92
14
Apr 24, 2019 07:27 PM
krazylowgsx
Dec 18, 2016 04:13 AM
deademon
Mar 31, 2016 09:25 PM
xjleitex15
Aug 18, 2015 01:23 AM
Subaru86
Aug 2, 2015 06:17 AM
