What is the Scion tC's alternator rated at?
Old Nov 1, 2004 | 04:43 PM
Tc_patentman's Avatar
Default What is the Scion tC's alternator rated at?
How many amps can that sucker generate? Can;t seem to find this info anywhere. There are a couple posts about replacing the alternator, but none which actually say what amperage the stock alternator can handle
Old Nov 1, 2004 | 05:00 PM
sciontc_mich's Avatar
hey.. it's actually 1200 watts according to the service manual.. which is actually 100amps.. i thought that was pretty high.. usually the civic's are like 75amps.. so hey maybe they anticipated people dropping amps in the car..
Old Nov 1, 2004 | 06:57 PM
NICE
Old Nov 1, 2004 | 08:12 PM
AciD's Avatar
when i picked my tC up from the dealer i asked. he told me it was 80amp. but 100 sounds better
Old Nov 2, 2004 | 12:07 AM
importproducts2's Avatar
Default alternators
EDIT:
please become a site sponsor to advertise
https://www.scionlife.com/premium/
Old Nov 2, 2004 | 06:10 AM
smurf3642's Avatar
The system I'm having installed is going to require a heavy alternator beef up...
I've heard it's 100 as well...weak...
Old Nov 2, 2004 | 12:51 PM
IF its truly 100 amps then I think I'm all right. I'm going for a good sound quality set up, not huge bass. I'm putting a set of MB quart PCE216 separates in the front run by an autotek 2200R amp (125WX2 at 4 ohms) and a single Adire Koda 10 in the trunk run by a 200-250W at 4 ohm amp (to be determined)
Was worried because a 500W system pulls an estimated 72amps at peak. I don;t listen to music ridiculously loud, so I figure I will never pull more than 40-50 amps off the alt with my set up during an everyday use. This leave 50-60 amps to run the car, which should be enough.
Old Nov 2, 2004 | 05:20 PM
Dulanic's Avatar
I can tell you right now I am running a 560W 6 Channel amp, and it has no issues at all.
Old May 14, 2007 | 05:52 PM
MTcX's Avatar
Scionetics
I am on a calling list for an alternator company so that as soon as a high output alternator becomes available I will be notified. Right now i am currently running about a 160 amp system that does really well but only because i swapped out the battery under the hood with a Kinetik 1800 series and have two Kinetik 800 series batteries in the hatch. My big problem now is that im changing out the system to about a 400-450 current amp system so the factory alternator is going to have issues. I will be using in this setup 2-3 of the 2400 series Kinetik batteries but that won't matter if I can't keep them charged up.
the problem why NOBODY makes a high output alternator for our car is that we have whats called a "hair pin" design winding meaning that instead of using round wire for the coil the wire is more like a square wire. I will post as soon as one becomes available. I will have the new system possibly before the alternator as well so i'll be posting up pics of that as well........its going to be LOUD though!
STCxB
11
Jan 9, 2015 04:30 PM
lunchbx05
Dec 29, 2014 07:53 PM
dgm458
Scion xD Drivetrain & Power
Dec 7, 2014 05:59 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
foxSCION
13
Dec 3, 2003 05:40 AM
