grinding when shift to 3rd hard everytime!!!
Old Jan 18, 2008 | 12:42 PM
bsp_in_sc's Avatar
Default grinding when shift to 3rd hard everytime!!!
ok so its been going on for like 2 weeks now, but everytime i throw it to 3rd gear, it grinds. this only happens when i do it kinda fast or hard, it wont happen if i do it slow.
what do you guys think the problem is, and how much would it cost... is it hard to fix?
Old Jan 18, 2008 | 12:54 PM
Crippie's Avatar
1UP Crew
have you noticed when you shift quickly, if your pushin the clutch as far in as when you do it slowly? that was happening to me when i swiched my clutch and had to get used to the new bumpstop
Old Jan 18, 2008 | 01:02 PM
bsp_in_sc's Avatar
no, i will hold the clutch all the way in, sit there and pass the shifter from 2nd to third to forth, to third, and everytime i go from anygear to third, never even releasing the clutch, it will grind everytime... when i do it fast or hard that is
Old Jan 18, 2008 | 01:03 PM
Crippie's Avatar
1UP Crew
syncro probably
Old Jan 18, 2008 | 01:15 PM
bencott's Avatar
yeah, someone else had a similar problem, except his would grind whenever he shifted into 3rd. here's the thread.
https://www.scionlife.com/forums/vie...129&highlight=
you should be still under warranty, so if the dealership decides the syncro is bad, they'll replace your transmission at no cost to you.
by the way, mine grinds when i try to shift into 3rd at high rpms, but i just take that to mean that i'm driving the car too hard.
Old Jan 18, 2008 | 01:31 PM
bsp_in_sc's Avatar
well, i have a short shifter, and pulley set, so i dont know if they will say that is that cause of it....
Old Jan 19, 2008 | 12:10 AM
bigwillystyle23's Avatar
i doubt it. theres been a few people with the same problem as you and they all got new transmissions.
Old Jan 19, 2008 | 05:55 PM
sp0t's Avatar
yeah, my 3rd gear grinded a lot too but it will disappear once the car is warmed up then im able to shift hard again. it's the synchros wearing out.
eric_m
52
Jan 17, 2019 05:50 AM
njb411
May 18, 2015 02:28 AM
zfxp
May 14, 2015 02:22 PM
ffodge
Apr 25, 2015 07:03 PM
hahajoey
61
Aug 21, 2004 03:46 AM
