Subs under the back seats...
Old 01-30-2008, 11:48 PM
ShaffNasty's Avatar
Default Subs under the back seats...
I was wonder if anyone has put subs under thier back seats... I was looking at it and thought it would be a good place to hide some 10's.. anyone have any comments? i am not sure whats underneath it all yet. But i am assuming probably the gas tank...
ShaffNasty is offline
Old 01-31-2008, 12:47 AM
lvbitwiz's Avatar
I have a PS2 and my video distro amps under the seat, it's a bit sung under there, you're not gonna fit 10's. theres about 9 inches of depth front to back and only about 4-5 top to bottom. but it's as wide as the seat if that's a plus
lvbitwiz is offline
Old 02-03-2008, 02:13 AM
ShaffNasty's Avatar
looks like 8's it is... gunna have to be custom..
Old 02-04-2008, 03:58 PM
PureAzn's Avatar
You're not going to get very good sound sticking subs under there. The foam is like 6" thick front to back. You're better off under-floor in the rear with the subs, and sticking amps under the rear seat.
PureAzn is offline
Old 02-04-2008, 07:23 PM
bigpapa's Avatar
I dont see any chance of any size sub fitting underneath the rear seat. Depth is not a problem, but the heighth will be a big problem.
bigpapa is offline
Old 02-05-2008, 12:26 AM
flying_toaster's Avatar
Elemental designs actaully make a custom enclosure that fit great right under either of the fron seats. its a 10'' slim sub. http://www.edesignaudio.com/edv2/pro...roducts_id=464
flying_toaster is offline
Old 02-05-2008, 02:23 AM
uberspeed's Avatar
Negative Ghostrider, that was for the Gen 1 xB, not for Gen 2. I waited for a while for them to redesign it for the Gen 2 and they were unable to, not enough space.
uberspeed is offline
Old 02-05-2008, 03:51 AM
VonStarINC's Avatar
the pattern is full.
VonStarINC is offline
Old 02-05-2008, 06:43 AM
ShaffNasty's Avatar
Hmmm slim fit 10" ehhh... i might make a custom box kinda like there one that goes over the spare tire... I dont want to take out the spare though...
Old 02-05-2008, 01:06 PM
PureAzn's Avatar
Spacewise it's gonna be tight if you don't for the rear, even flipping the tire over. Under the driver's seat is a lost cause, and the passenger isn't *that* much better. If you want unobtrusive, you can go custom fiberglass along the sides/cubbies, and if you want stealth your only option right now is to remove the spare.
BTW, for the person that said you can go straight across under the rear seat - not quite true, there's a hump in the middle that you'd have to work with/around.
Essentially, your rule for under the rear is 13x9x2 max before you have to cut the seat. (And the 13" has to go side to side, 9" depth is still giong to get a bit of pressure from the seat)
PureAzn is offline
Old 02-05-2008, 11:51 PM
lvbitwiz's Avatar
Cubby sub
lvbitwiz is offline
Old 02-06-2008, 01:44 AM
uberspeed's Avatar
Correct sir ;)
uberspeed's Avatar
lvbitwiz, are those the new slim subs from soundstream!? How does it sound? What are you powering it with? Details please!
Old 02-06-2008, 01:58 AM
lvbitwiz's Avatar
It's their PW-10S but it's not slim. The enclosure is a tad over .6cf, all glass except for an MDF ring. I have a Kicker ZX700.5 driving it (wired for 2ohm) and the rest of my speakers (polks all aound). It sounds nice, granted I'm not at all going for spl but it dosen't do a bad job at all. I have noticed it being a bit boomy around 35-40hz but I'm attributing that more to the enclosure than the sub itself. May build another one and try to eek out a bit more room in it without losing my trunk. I have the SNS for the head and am using a Navone LOC to bring RCAs to the amp.
lvbitwiz is offline
Old 02-06-2008, 02:37 AM
Utah Scions
xseveredveganx's Avatar
lvbitwiz, did you use polyfill? It could peak at that frequency because of the box being on the smaller side. The smaller the box, the higher the tuning. The larger the box, the lower. That's why strict SPL guys run tiny boxes with HUUUUGE ports.
The polyfill should help. It'll make the enclosure act larger because it slows down the rear wave of the subwoofer.
xseveredveganx is offline
Old 02-06-2008, 02:49 AM
lvbitwiz's Avatar
It's late and rather than run the risk of death tearing apart one of my kid's teddy bears, Ill go to walmart tomorrow
lvbitwiz is offline
sako
03-11-2015 01:27 AM
TheSilencerTC
Scion tC 2G ICE & Interior
02-24-2015 04:56 PM
ninoTc
02-09-2015 07:08 AM
missing_image
02-07-2015 07:18 PM
linlow
Scion tC 1G ICE & Interior
12-14-2014 12:56 AM
Quick Reply: Subs under the back seats...
