Headlight Problem
Old Feb 5, 2008 | 03:47 AM
OC_ScionBox's Avatar
Default Headlight Problem
how do you fix when one headlight is brighter than the other??
i know its not the bulb because i swap them out and still looks
the same
could it be the harness maybe??
i really need to fix this because its annoying
any help out there??
Old Feb 5, 2008 | 03:50 AM
Dkfung88's Avatar
brighter? are they aligned?
Old Feb 5, 2008 | 03:59 AM
draxcaliber's Avatar
uhm...before we help you, you do know your driverside bulb is supposed to be aimed a bit lower than your passengerside bulb so they don't blind oncoming traffic right?
Old Feb 5, 2008 | 04:04 AM
what are you guyz talkin about?????????????
i dont think that made a difference, still comes out the same
Old Feb 5, 2008 | 04:13 AM
what i'm trying to say is that the low beams on all cars are designed to focus and aim the light created from the bulbs in the housing. the headlight housing on the passenger side is aimed higher and further than the driverside because the driverside light is closer to oncoming traffic, so it is designed to aim lower than the passengerside bulb to make sure not to dazzle oncoming cars.
this isn't a property of the bulb, it is a property of the headlight housing itself.
so i am trying to make sure that you are taking about one of your headlights being noticibly dimmer than the other one, or is it because you didn't realize that your headlights don't focus light in exactly the same pattern.
Old Feb 5, 2008 | 04:59 AM
okay, from your lack of response, i'm going to guess i was right?
Old Feb 5, 2008 | 05:01 AM
burstaneurysm's Avatar
Uhm... yea.
Old Feb 5, 2008 | 10:12 PM
i think that it could be the harness maybe??
how can i fix it??
Old Feb 5, 2008 | 10:26 PM
if it is the harness, you replace it, or make sure there is nothing preventing it from getting a good connection.
Old Feb 5, 2008 | 10:36 PM
about how much is a replacement harness and where can i get one?
Old Feb 5, 2008 | 11:05 PM
before you go trying to replace parts that might not even be the problem, why don't you take it to get diagnosed first and make sure you replace the right parts.
Old Feb 6, 2008 | 01:07 AM
Metro273's Avatar
The reason for one dim headlight is a bad ground somewhere in the headlight harness. Follow the headlight harness to a ground or common ground, remove the bolt holding the harness to the body, clean the bolt, mating surface and ground eyelid real good and reattach harness to body.
If that don't work, time to take it to the dealership for a proper diagnosis...good luck!
Old Feb 6, 2008 | 04:23 AM
where is the bolt holding the harness to the body located at??
Old Feb 8, 2008 | 03:08 AM
Scorpius01's Avatar
It is all in the wiring diagram. If you do not have access to it, then take it to a dealer.
Old Feb 9, 2008 | 06:53 AM
AKScionxb's Avatar
i have HIDS installed in my box but then when i came out with the autostart going, my drivers side light was flickering and the passenager side wasn't, i switched out the bulb thinking it was in the HID wiring system but when i wire it back to a original oem bulb still flickering any ideas?
Old Feb 11, 2008 | 09:57 PM
Scorpius01's Avatar
Did you splice the HID kit into the factory harness? Do you have access to a multimeter? I can provide the wiring diagram.
Old Feb 13, 2008 | 02:11 AM
AKScionxb's Avatar
no i don't access to a mulitmeter? i dont even know what that is. and i got the HID plug and play kit from oznium. i'll get a pic and show you guys what i'm talking about later tonight.
Old Feb 13, 2008 | 05:36 PM
Scorpius01's Avatar
flickering is caused by a bad connection or an intermittant short (broken wire, etc...)
Old Feb 17, 2008 | 07:17 AM
AKScionxb's Avatar
so how do i fix it?
Old Mar 30, 2016 | 05:02 AM
bB2NER's Avatar
Music City Scions
Found out that one dim headlight is usually a blown headlight fuse. Fixed mine when I did a yahoo search that led to club xB and the answer.
S7ephavs
Mar 22, 2015 12:09 PM
2006whitexb
Mar 11, 2015 12:39 AM
missing_image
Feb 7, 2015 07:18 PM
scsteven
Jan 25, 2015 01:06 AM
