5 Axis Body Kit
Old Apr 3, 2008 | 01:58 AM
nvrmnd05's Avatar
Default 5 Axis Body Kit
I have the 5 Axis body kit and the rear is peeling away from the original bumper. Anyone else have this problem? I hope it's not a huge deal for my friends at the dealership to fix!
Old Apr 3, 2008 | 02:02 AM
bBlover's Avatar
rear is peeling away?? please be more specific!
Old Apr 3, 2008 | 02:41 AM
randomsuper's Avatar
it was more than likely poor prep which caused the tape to fall off. take it in and have them do it right this time. no worries.
Old Apr 3, 2008 | 02:19 PM
bosssadler's Avatar
im in houston to, and i went through a similar problem with my mustang, its a combo of houston humidity/weather and maybe just a bad strip of M3
take it to a shop, or take it off clean it well with soap and water, the with rubbing alcohol. then reapply a new strip of M3 tape
Old Apr 3, 2008 | 02:26 PM
tCTaco's Avatar
Yeah, mine is doing the same thing.....I preped it correctly, but i think it was a lil to cool outside when I installed it. not with the warm nasty weather tight now, one side seems to have drooped a lil.
Old Apr 3, 2008 | 02:48 PM
MikeInABox's Avatar
I wonder if some of the backing was pulled away and overspray got on the tape. I've seen a few pics where that has happened.
Old Apr 13, 2008 | 07:40 PM
ScioXBox's Avatar
So what's everyone done to solve this issue? I have the same problem, I added the mud guard protector but didn;t not add another layer of tape to compensate so mine is also pulling away in the middle. I plan on using a couple of small screws (from the back) or some 5 minute epoxy..
Mud guard protector for cleaner look.
Old Apr 22, 2008 | 12:26 AM
jefftallica's Avatar
The mud guard is clean. Hows the rest of the kit holding up? Can you still fit through the car wash guide rails? Planning on getting the kit soon. Thanks.
Old Apr 23, 2008 | 04:57 PM
_Doug_'s Avatar
We used an epoxy to hold the back piece on. The contact patch for the 3M tape is minimal....so we found it necessary to use something extra. Works great!
Old Apr 25, 2008 | 12:09 AM
KUxB's Avatar
i had the same problem with mine plus my sides where doing it as well. I took it back to the dealer. They put new 3m tape on it. the tape that came with the kit is not very good. They also put a silicon strip around it so that water and dirt wont get in there and losen up the tape.
Old Apr 25, 2008 | 12:15 AM
tCTaco's Avatar
Mines up for sale....Check the sig
Old Apr 26, 2008 | 01:49 PM
SmartAss's Avatar
Ive had mine on there for about 8 months no problems with it, just prepped really well, alcohol pad the placement area and heat up the double side and paint on the car and kept pressure on it for a bit.
viciouzgamer
Mar 27, 2015 12:16 AM
kagero79
40
Jul 17, 2006 07:01 AM
JDMxB
Scion xA Aero & Exterior
14
Dec 28, 2003 05:39 AM
tbblizzard
Dec 16, 2003 08:36 PM
vho
Dec 9, 2003 11:44 PM
