will i get rasp
Old Apr 5, 2008 | 05:49 AM
joeya28's Avatar
Default will i get rasp
with TRD axle back, custom mid pipe with 2 18" designators and Alphawerks Headers and a mid pipe
Old Apr 5, 2008 | 05:52 AM
curtislo9's Avatar
answer is, yes.
Old Apr 5, 2008 | 06:02 AM
joeya28's Avatar
even with the 2 18" res?
Old Apr 5, 2008 | 06:22 AM
O5_TRD_tC's Avatar
Default Re: will i get rasp
wth is a 'designators'?
curtislo9's Avatar
It is possible. I'm not 100% but, I'm pretty positive you will still have "a little" at WOT. My reasoning is that your TRD exhaust is one of the raspiest exhausts on the market. A 4-1 header if also raspier than a 4-2-1, which I have. When you plan to change your S-pipe, which you really really really should, you will have more rasp.
You really really really should consider buying a s-pipe. Because a custom midpipe does almost nothing for you without a spipe. There are other threads explaining this. It's like a bottlekneck effect.
Old Apr 5, 2008 | 06:23 AM
joeya28's Avatar
hahaha what a stupid typo resonator... i guess i got a red line and didnt really look at the spell check
Old Apr 5, 2008 | 06:27 AM
curtislo9's Avatar
Yeah, try it out. If it doesn't solve the rasp problem, change it up.
Old Apr 5, 2008 | 06:29 AM
joeya28's Avatar
you think it can be solved or cut down by buying a different axle back?
Old Apr 5, 2008 | 06:35 AM
curtislo9's Avatar
Yes definitely.
For example, the Tanabe Touring Medallion is a great OEM style exhaust that will mute rasp almost by itself. Also, the Tanabe Concept G is one of the quiet on the market also. But like I stated before, TRD is one of the raspiest.
Old Apr 5, 2008 | 06:40 AM
joeya28's Avatar
thanks for the input. its a reasonable upgrade to fix a annoying problem like rasp. ill look in to it after i hear my set up
Old Apr 5, 2008 | 11:39 PM
highvoltage1's Avatar
well you may still have some but you will for sure if you get an s-pipe but I'd search cause there some guys who used bigger resonators and got lil to no rasp. GL!
Old Apr 5, 2008 | 11:45 PM
Saint51's Avatar
Good luck to ya, the answer to your original question is yes, but like curtis said, try one of the other exhaust and you should have better luck! let us know how you end up doin it!
Old Apr 8, 2008 | 12:32 AM
joeya28's Avatar
how would a megan sound ?
Old Apr 8, 2008 | 03:54 AM
Sgarcia1129's Avatar
I'd like to do the same thing with mine let me know what happends when you put it all on
2CTC
Sep 12, 2015 11:33 AM
stenger
Jun 10, 2015 05:05 AM
agmech
Apr 20, 2006 01:56 AM
peterbilt
Jan 9, 2006 02:26 PM
05-RS1
27
Jan 6, 2006 02:10 AM
