T1809 premium HU Aux problems
Old Apr 13, 2008 | 07:53 PM
thelgnd's Avatar
Default T1809 premium HU Aux problems
I just replaced my stock 07 head unit (T1807) with a 2008 premium HU (T1809) and it really is plug and play but the aux button is not responding on when I plug my ipod into the minijack. I plan on getting the ipod cable but it would be nice to still be able to use the minijack aux input.
I've tried everything, like having the ipod playing (and plugged in) then turning on the HU, or turing on the HU and then plugging in the ipod. Still no reponse from the new HU.
Any help?
Old Apr 14, 2008 | 05:59 AM
sciontc_mich's Avatar
make sure the 2nd wiring connector is connected firmly. That has happened before and no AUX.
Old Apr 14, 2008 | 10:02 AM
SquallLHeart's Avatar
and though it's a little obvious.. make sure you plugged in all the plugs in the back of the radio.
Old Aug 24, 2011 | 11:43 PM
Evo6Z28's Avatar
I just replaced my stock t1807 hu with the t1809 and my aux port does nothing as well.is there something different in the wiring that is preventing it from recognizing the port?
Old Aug 25, 2011 | 03:56 PM
tCjosh's Avatar
the AUX doesnt work on the premium HD on '07 and older tC's... i have the same HD in my '06 and after a lot of research, you need to get two parts to make your iPod work with this HD. part # PT546-21062 and PT546-21061 is what you need if your tC didnt come with a premium unit. if it did, then all you need is PT546-21062. therer are a lot of threads on here about this same question.
Old Oct 27, 2011 | 09:29 PM
Evo6Z28's Avatar
I found the solution for the aux port problem guys. You have to put a resistor between the number 14 pin and the number 16 pin on the 20pin connector on the back of the t1809 radio.so basically jump the terminals going into the HU.
Old Oct 30, 2012 | 08:22 PM
Berett315's Avatar
Default T1809 aux connection possibility
What does that even mean? I just got the t1809 hooked up in my 4runner and it works great but about to make a project on getting that aux working. from the information i was able to get, it seems that the older model HUs (t1808, etc)had aux capability running from the same plug as the steering wheel controls and the ipod controls were obviously separate, located in the lower plug and used the sc12235 (sp?)
If im not mistakened, has the t1809 rerouted the connections to where now both the aux and ipod controls come from the bottom connection in the back of the t1809? really just need the aux controls but i wish it were as simple as buying the sc12235 off ebay, and splicing it w/ a 3.5 mm jack
wiltonhall
Jun 23, 2025 10:09 PM
mischman
Jan 14, 2015 06:07 PM
Beesh
Jan 9, 2015 06:30 PM
RichBinAZ
Dec 21, 2014 12:05 PM
ScionLife Editor
Dec 6, 2014 11:58 PM
