Knocking in the windshield area (im guessing)
Old Apr 30, 2008 | 06:00 PM
shupes31's Avatar
Default Knocking in the windshield area (im guessing)
Up here in the southeast corner of wisconsin, it's been getting cold these past few winters. When it gets to around 15 degrees or lower, there is a very loud knocking sound when i go over bumps. Has anyone experienced it/ had it fixed? again, it only happens when it gets really cold.
Old Apr 30, 2008 | 06:12 PM
jurassic1's Avatar
Sure it's the windshield and not the sunroof?
Old Apr 30, 2008 | 09:01 PM
Scott8's Avatar
I get that whenever it's below 20 out. not sure what it is, but I am sure it has something to do with the gas in the shocks being really cold.
Old Apr 30, 2008 | 11:50 PM
shupes31's Avatar
yeah, im sure its the windshield area. ive tried closing the sunroof, and it already is all the way. and if it's the shocks. wouldnt i be hearing it from all around and not just the front?
Old May 1, 2008 | 12:08 AM
Scott8's Avatar
there is a lot more weight on the front with the engine, and you probably don't notice it if it is since you are right on the front.
Mines done the same thing as you for the past 3 years in the really fridgid cold. nothing during the summer at all
Old May 1, 2008 | 12:16 AM
shupes31's Avatar
alright, thanx scott.
{thread closed}
Old May 1, 2008 | 12:19 AM
Scott8's Avatar
LOCK IT UP!!!!!!!!!!!!!!!
Old May 1, 2008 | 12:33 AM
MeatRocket's Avatar
your windshield is loose, put some locktite on it and you should be set to go.
j/p i have the same issue and i had it checked and they found nothing wrong. My dealer blamed it on my injen cai.
Old May 1, 2008 | 01:02 AM
BoostedBeastBox's Avatar
The exact same thing happens to my car when it mad cold out , def comes from the windsheild area i just ignored it now its warm out so its all good.
Old May 1, 2008 | 01:12 AM
toeveryhour's Avatar
yeah it could very well be your intake, i know injen does that a lot (the knocking), otherwise it's just normal how the way materials contract when it gets cold outside... more play room.
Old May 1, 2008 | 01:24 AM
Scott8's Avatar
Originally Posted by toeveryhour
yeah it could very well be your intake, i know injen does that a lot (the knocking), otherwise isn't just normal how the way materials contract when it gets cold outside... more play room.
Mine does it without an intake
Old May 1, 2008 | 05:32 AM
Jdub86's Avatar
MN Scions
Mine would do that too. I was trying to figure out what it was but I have no idea.
Old May 4, 2008 | 03:41 AM
Teare's Avatar
Default There is a TSB for this
I had the same problem with my 07. It's a free fix at the dealer. It is listed under TSB NV009-06.
From the TSB:
If a creak, tick, or rattle noise is heard at the top or bottom of the windshield, the source
of the noise may be the two windshield stoppers bonded to the top of the windshield or
the windshield retainers bonded to the lower edge of the windshield. This bulletin
provides the recommended repair procedure to eliminate these types of noises from the
windshield area.
Heres the link
http://matrixowners.com/tsb/TS-NV009-06.pdf
lsjimenez
Apr 3, 2015 01:32 PM
D_Roke
Mar 31, 2015 05:37 PM
toyotaisme
Jan 10, 2015 10:24 PM
eric_m
79
Mar 17, 2013 12:21 AM
dchan8
34
Mar 26, 2004 04:37 AM
