View Poll Results: which one is better?
Shaved
52.38%
Extra reverse lite added
47.62%
Voters: 21. You may not vote on this poll
Rear Bumper ideas
Old May 10, 2008 | 12:10 AM
bosssadler's Avatar
Default Rear Bumper ideas
Arguing with my buddy about what rear end looks better so ill leave it to you
Old May 10, 2008 | 12:58 AM
boooosty's Avatar
1UP Crew
Shaved....the shaved reverse and the scion logo makes it look so clean!
I love it!
Old May 10, 2008 | 02:46 AM
oreoremix42's Avatar
I agree with just the 2 reverse looking better. With the revese like that get a dual exhuast it will look perfect then
Old May 10, 2008 | 02:50 AM
Whispaz's Avatar
I like the shaved look too but you'd need the Rumion tails to get a reverse light.
Also, in the rear window there will be a "bump" from where the emblem is located so it wont be perfectly level as shown in that picture. this will make it look like somethings missing.
Old May 10, 2008 | 04:15 AM
AAG's Avatar
AAG
DeepSouth Scions
Shaved looks alot better but I would do the extra reverse light for function
Old May 11, 2008 | 02:28 AM
bosssadler's Avatar
well i would but the reverse light in the top square of the tail lights
Old Aug 23, 2008 | 08:31 PM
whartman77's Avatar
now wouldn't it be cool if you put the reverse lights in the tails and still did the dual cutouts for the reverse lights in the bumper and routed a dual exhaust through those?
Old Aug 23, 2008 | 08:47 PM
CIONIDE's Avatar
I thought about just routing a single exhaust out the reverse light hole in the bumper, but if you look under the rear end, you will see metal chassis framing behind the bumper that is in the way. Nice thinking though.
Old Aug 23, 2008 | 09:01 PM
whartman77's Avatar
Default blocking the way?
Is it really the chasis? I thought that was just the bumper frame; haven't really gotten under to check it out, but good point either way!
Old Aug 25, 2008 | 07:24 PM
ATxB's Avatar
WOW!! i love the shaved look! in fact you just gave me an idea to do to mine. that is gonna look sick if you shave that. I think im gonna shave my bumper and go with tailights with reverse in them. that looks so much better
how much would something like that cost? plus with the new taillights?
Old Aug 25, 2008 | 07:36 PM
bosssadler's Avatar
well i bought some tails and cut them up, it doesnt look to easy, and as of now there is no after market tail with the reverse light in them, the only one that does is the Rumion tails.
Old Aug 25, 2008 | 07:52 PM
ATxB's Avatar
do they make them for the xb2's?
Old Aug 25, 2008 | 08:32 PM
KoolBox's Avatar
I like the doble back up light and eventually i'll do it to my.
Old Aug 26, 2008 | 12:24 AM
CIONIDE's Avatar
Rumion tails with shaved rear bumper, from the thread Taillights:
https://www.scionlife.com/forums/viewtopic.php?t=202758
Originally Posted by motorcade
I just installed the Rumion tail light in my XB. It only took about 5mins to change the wire plugs over.
Old Aug 26, 2008 | 03:03 AM
xseveredveganx's Avatar
Utah Scions
Good luck with that. I'm not sure if you've planned on using an actual second reverse light, but it won't work. The OEM reverse light has too many curves to it and you can't just simply turn it upside down.
My recommendation if you want more lighting in reverse is to purchase the TYC tails and modify them. Swap out the turn signal bulbs with some white ones and do some rewiring. It wouldn't be difficult at all.
Old Aug 26, 2008 | 03:49 AM
CIONIDE's Avatar
...or just get the Rumion tails for about the same price - no rewiring necessary.
Old Aug 26, 2008 | 04:41 AM
Utah Scions
Getting the Rumion tails and bolting them up isn't just that simple. The above mentioned xB with the Rumion tails had to make fillers because there was a gap. If you don't mind gaps bigger than Letterman's teef, than by all means scoop them up. But there is also rewiring needed.
Quote from the cat with the Rumion tails:
The only thing about the install, is the bottom of the light needs a fillier panel its has a small gap. In a little while i will have a kit available. It will include the Lights and filler panel.
Old Aug 26, 2008 | 04:53 AM
CIONIDE's Avatar
I've seen a couple other people with the Rumion tails, and none of them mentioned gaps, although I don't know for sure. Even so, Letterman has done OK with the gap.
Old Aug 26, 2008 | 11:41 PM
whartman77's Avatar
maybe he's talking about the big gap that would be left in the bumper; but that wold be taken care of with the shaving that was mentioned earlier! :-) I personally like the oddball reverse light; kinda keeps a balance to the exhaust tip unless you are running dual exhaust...
Ferretgrrl
Oct 15, 2018 02:50 AM
umnitza
Dec 1, 2014 06:26 PM
sensez
22
Nov 19, 2003 04:03 PM
sensez
22
Oct 29, 2003 04:09 PM
1NZ-FE
22
Sep 28, 2003 09:50 PM
