got fogs and autodimming mirror installed. one problem...
Old May 20, 2008 | 07:48 PM
05sciondude's Avatar
Default got fogs and autodimming mirror installed. one problem...
love the fogs and the autodimming mirror but i think my local toyota dealership installed the mirror wrong. the ambient lighting and autodimming part stay on all the time. even when the key is out and i lock it up. so i got to remember to turn it off so i dont kill my battery. looks like i will have to take it back to the stealership to get them to correct that.
Old May 20, 2008 | 11:59 PM
xtigger's Avatar
hmm, when i got it install it turned off when i took the key out, but i no longer have the TC but yea i don't know why it stays on tho go back and ask the dealer wtf is this.
Old May 21, 2008 | 02:47 AM
AcidDrop's Avatar
i believe that lights stays on the whole time, a friend bought her tC with already installed and i always see it on when the car is turned off and it hasn't killed her battery at all.
Old May 21, 2008 | 02:59 AM
tito_tc's Avatar
It turn off wend you turn the car off I got me from factory
Old May 21, 2008 | 03:08 AM
AcidDrop's Avatar
Old May 21, 2008 | 04:21 AM
cmv138's Avatar
according to the instructions they wired it through the sun roof plug. i did it that way and have the same issue. there is another set of instruction that you run a wire to the passenger side behind the glove compartment and there is a plug to tap into. i havent had time to fix my auto dim mirror.
Old May 21, 2008 | 08:17 PM
B_Izzle's Avatar
i have it wired/tapped into the sunroof power/wire harness, and it works perfectly for me.
some things to note:
1) autodimming feature and mood light feature should turn off when car is turned off. You can tell if the autodimming is off by looking at the small LED on the front of the mirror by the buttons
2) mood light turns off when there is lots of light, i.e. when you're outside during the day. it will then turn back on when it detects that you're in a low-light situation.
3) pilot light (not the mood light) can turn on any time, even when the key is not in the ignition.
Old May 22, 2008 | 01:42 AM
cweckel2000's Avatar
They probably used the wrong power wire. If they used the power to the map lights, it'll be active when the car is off. If they did it correctly and used the moonroof power it will shut off when the car is off.
steeze69
May 24, 2021 02:57 AM
alexdrummerr30
Sep 8, 2018 12:18 PM
hondajt
Dec 14, 2015 12:54 PM
OpTicaL
Sep 16, 2015 10:25 AM
