FIXED: Sunroof/Headliner Plastic Rattle
Old Jun 8, 2008 | 06:47 PM
RodC's Avatar
Default FIXED: Sunroof/Headliner Plastic Rattle
I think I fixed all my hatch rattles, but a new rattle just developed last week. Something has started rattling in the sunroof area. I believe it's not the sunroof itself, but the retractable plastic sun-screen. It's extremely annoying, and it happens whether the screen is open or closed.
I am contemplating removing the sun-screen completely, but I can't be sure if that will solve the problem. Has anyone else experienced this one?
Old Jun 8, 2008 | 08:17 PM
deadtoaster2's Avatar
I had one that I could have sworn was coming from the sunroof but it is hard to pinpoint it when you are driving down the road. I might also add that I almost always drive alone. So a few days later I had someone in the passenger seat and was going to ask them to see if they could try to figure out where it was coming from, only problem is it never happened. So later that day it started rattling again and I FINALLY figured out that it was the passenger seat belt rattling between the door panel thing and the slider **** on the side of the seat to make it fold forward. I plugged it into the seat belt socket and it stopped rattling.
Now why it sounded like it was coming from the sunroof, I have no idea. Make sure you check out this possibility first as I hadn't heard anything about it before on here.
Old Jun 8, 2008 | 08:22 PM
Yanki01's Avatar
mine does it but the rear sunscreen thing. I think im able to stuff something under the headliner to stop it because if i put pressure back there it stops. now i just need to get off my lazy a$$ and do it.
Old Jun 8, 2008 | 08:23 PM
RodC's Avatar
Hmm, okay I will definitely check that out first. I once had a really loud knocking sound which I thought was coming from the roof, but I eventually discovered that the passenger seatbelt had become twisted and failed to reel in automatically, and the metal clip was swinging around behind the seat and bashing against a plastic panel.
On a related note, I am also getting a lot of clicking/rattling sounds coming from the driver's seatbelt clip while the seatbelt is connected and the car is in motion. Have you experienced this one? Every time I fix a rattle, it seems like another one starts.
Old Jun 8, 2008 | 08:25 PM
RodC's Avatar
I was thinking about using some foam tape in that area. Although I haven't been able to pin down the problem yet. It's hard to stretch all the way back to apply pressure to the rear roof area whilst driving.
Old Aug 27, 2008 | 09:29 PM
RodC's Avatar
So 2 or 3 months later, and I have finally fixed this annoying rattle. Although it sounded like the sunscreen, it was actually coming from all around the rim of the sunroof and moonroof openings. There are plastic pieces which "frame" the roof openings, and these pieces are able to move up and down over bumps, impacting against the roof itself.
The solution was these little babies from Ace Hardware:
http://www.acehardwareoutlet.com/(zzz2ag45fa4ndnii4r54za45)/ProductDetails.aspx?SKU=5089560
Best 3 bucks I ever spent. To perform the actual fix, I pried the fabric headliner away from the sunroof and moonroof openings and wedged some of these adhesive pads into the gaps where movement was occurring. I used about 16 in total, until there was no longer any movement when I applied pressure to the roof area around the openings.
I'm not sure if anyone else has ever experienced this same rattle, but if anyone needs a walkthrough then I can provide pics and more detailed instructions.
Problem solved, w00t.
Old Aug 27, 2008 | 10:55 PM
Yanki01's Avatar
any pics of "where" you mounted them would be nice.
Old Aug 27, 2008 | 11:07 PM
RodC's Avatar
Yeah I'll get some pics this weekend. It's a little bit hard to describe without pics, but in the meantime I will try...
The front section is the easiest to describe. If you are sitting in the driver's seat, look up at the front edge of the moonroof where it meets the headliner. There is a portion of the headliner between the moonroof and the sun visors which has a lot of freedom of movement. If you tap this part upwards with your hand then you should hear plastic rattling noises.
So once you identify the noisy part, the goal is just to deaden its ability to move. Get your fingers "behind" the edge of the headliner and pull it downwards and towards yourself as much as you are comfortable with. After you peel back the headliner a bit, you should be able to squeeze your fingers under the headliner and into the gap which exists between the plastic moonroof frame and the roof itself. The gap is maybe a quarter of an inch, so the objective here is to wedge these little foam and rubber tabs inside this gap, eliminating the freedom of movement. The process isn't pretty and takes a bit of trial and error. It took me about 20 minutes of working blind with my fingers trying to force the pads inside the gap. I think I only used 4 pads on the front section, and then repeat for the sides and the rear until you can no longer hear any sound when you tap on the headliner around the glass parts.
Old Sep 16, 2008 | 10:56 PM
elpolloblanco009's Avatar
I kinda have this problem. There is this insanely annoying rattle of the front moonroof shade. I can make it go away just by putting my finger on it. It's right over the passenger seat. I'm gonna figure out a way to get rid of it cause it drives me NUTS. maybe some of those pads will work
Old Sep 17, 2008 | 01:03 AM
RodC's Avatar
Yes, this will fix it.
Old Sep 22, 2008 | 04:28 PM
MountScion1's Avatar
pics would be great, I took my headliner down two years ago and sound-deadened it best I could, it was good for a while but the rattle always comes back...... definitely see about putting up some pics
Old Sep 22, 2008 | 05:18 PM
HR_Guy's Avatar
So how did you fix your hatch rattle? I tried the electrical tape around the metal latch and the foam pads around the rubber stoppers, but it lasts for like 2 days and starts up again. None of the other methods I've seen here have worked for me.
Old Sep 22, 2008 | 05:43 PM
RodC's Avatar
Actually, the hatch rattle seems to come back for no reason. Just when I think I've fixed it, it's back again. I just used all sorts of combinations of foam tape and electrical tape, and it was gone for a couple of months at one point. Now it's back.
Old Sep 22, 2008 | 07:01 PM
HR_Guy's Avatar
Yeah, same here. Oh well, I'll keep messing with it. I had an annoying glove box rattle that I fixed similarly to what you did with the sunroof, just need to figure out a way to fix the $%&*ing hatch rattle...
Old Sep 22, 2008 | 07:03 PM
RodC's Avatar
Oh yeah, the glovebox rattle. Mine was rattling from being too loose in the top-left corner, but some adhesive foam fixed that.
Old Sep 22, 2008 | 07:09 PM
Keith's Avatar
any pics of the opening ?? by the sun roof...
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
SoccerBoy_AP
Oct 1, 2015 06:28 AM
user9430961
Sep 24, 2015 01:09 PM
paisatronix
Sep 5, 2015 04:13 AM
