Running fi/c with no maf clamp
Old Dec 3, 2008 | 04:32 PM
jjos1's Avatar
Default Running fi/c with no maf clamp
I want to run my fi/c without clamping my maf, I have a modded injen maf holder which seems to be causing problems with the voltage readings. I was running my kit on 7psi with no fuel managment and it was running good af's across the board. Can I enter 0 in all the charts and set a max voltage of 5.05 volts ? will having no values set cause problems ?
Old Dec 3, 2008 | 05:17 PM
gompka's Avatar
I'm not expert but I was under the impression that having a map with all 0's just means the fi/c passes through the signal without modifying it.
Old Dec 3, 2008 | 05:37 PM
thendawg's Avatar
As long as u have it set to percent mode rather than voltage mode yes u can have all 0's entered and it will just pass through
Old Dec 3, 2008 | 10:43 PM
jjos1's Avatar
^ do you still have to set a max voltage ?
Brammi
Nov 13, 2016 03:46 AM
hata
Sep 8, 2015 01:58 AM
tha17
Feb 5, 2015 12:56 PM
cid_mcdp
Jan 5, 2015 02:45 PM
Phillip_Injen
53
Jan 17, 2004 01:56 AM
