small shaft play... normal?
Old Feb 20, 2009 | 03:34 AM
turbo_tC4's Avatar
Default small shaft play... normal?
on my intake side of the turbo i can move it side to side but very little. and very little in and out. is this okay?
Old Feb 20, 2009 | 06:35 AM
SoFloTC's Avatar
u can move it in and out? thats bad .. even if its a little.
Old Feb 20, 2009 | 12:04 PM
aen's Avatar
aen
no, it better move a little, it needs room to expand and contract, metal expands under heat.
BUT. depending on the amount it could be excessive
Old Feb 20, 2009 | 12:24 PM
JOEinSD's Avatar
Default Re: small shaft play... normal?
Title of thread: small shaft play... normal?
Originally Posted by turbo_tC4
...i can move it side to side but very little. and very little in and out. is this okay?
Sorry. Just had to..
Old Feb 20, 2009 | 02:09 PM
turbo_tC4's Avatar
i had the turbo rebuilt under the turbonetics warrenty. i got it back after it was rebuilt and balanced. I ended up having my piston rings fried. Car was smoking blue tint from exhaust and smoke came out of oil cap and spark plug hole. Oil was bubbling out from the exhaust side of the turbo. Are those normal symptoms of piston rings fried? And i DONT think that a turbo would go bad after starting the car to get tuned after its rebuilt and balanced...
Old Feb 20, 2009 | 02:29 PM
thendawg's Avatar
having the same problem i had - probably your ring landings are gone - if its smoking badly from dispstick and crnakcase vent. The blowby will actually prevent the oil from draining back into the pan and it will go out through the turbo's oil seals. Seems to me to be exactly what youre experiencing - turbo is fine - the motor is not
Old Feb 20, 2009 | 02:43 PM
turbo_tC4's Avatar
but how come there was "little" shaft play on the intake side of the turbo? i mean it was just rebuilt and balanced a few days before i put it on. I noticed "small" in and outs
Old Feb 20, 2009 | 04:56 PM
SoFloTC's Avatar
a little shaftplay is normal but in and out isnt good either way.
Old Feb 20, 2009 | 06:24 PM
turbo_tC4's Avatar
but how is it possible that a turbo which was just rebuilt and balanced go bad after one dyno run while tunning?
Old Feb 21, 2009 | 12:22 AM
toyota_scion_tc's Avatar
If it was properly primed with oil then no, if it wasn’t then yes. End play is normal to an extent the turbochargers are manufactured that way so the oil flowing in the bearing should take up all of the slack assuming it isn't excessive. Put oil in the oil feed line fitting rotate the shaft and you should feel almost all of the end play gone.
Old Feb 21, 2009 | 01:53 AM
aen's Avatar
aen
if it was balanced and rebuilt by a reputable shop, and builds boost and doesn't smoke why would you have checked shaft play in the first place?
DaBlackBox
134
Apr 10, 2022 02:04 PM
rain7905643
12
Jun 13, 2018 05:34 AM
nazblue5807
Apr 11, 2015 12:20 AM
annika
Mar 16, 2015 06:36 PM
