small shaft play... normal?
Title of thread: small shaft play... normal?
Sorry. Just had to..
Originally Posted by turbo_tC4
...i can move it side to side but very little. and very little in and out. is this okay?
Originally Posted by SoFloTC
u can move it in and out? thats bad .. even if its a little.
i had the turbo rebuilt under the turbonetics warrenty. i got it back after it was rebuilt and balanced. I ended up having my piston rings fried. Car was smoking blue tint from exhaust and smoke came out of oil cap and spark plug hole. Oil was bubbling out from the exhaust side of the turbo. Are those normal symptoms of piston rings fried? And i DONT think that a turbo would go bad after starting the car to get tuned after its rebuilt and balanced...
having the same problem i had - probably your ring landings are gone - if its smoking badly from dispstick and crnakcase vent. The blowby will actually prevent the oil from draining back into the pan and it will go out through the turbo's oil seals. Seems to me to be exactly what youre experiencing - turbo is fine - the motor is not
a little shaftplay is normal but in and out isnt good either way.
If it was properly primed with oil then no, if it wasn’t then yes. End play is normal to an extent the turbochargers are manufactured that way so the oil flowing in the bearing should take up all of the slack assuming it isn't excessive. Put oil in the oil feed line fitting rotate the shaft and you should feel almost all of the end play gone.
DaBlackBox
134
Apr 10, 2022 02:04 PM
rain7905643
12
Jun 13, 2018 05:34 AM
