injen short ram intake installation xB?!?
Old Jan 22, 2004 | 10:41 PM
morph1119's Avatar
Default injen short ram intake installation xB?!?
Hey buds, anyone know a site or have the instructions to installing the intake? Or a place around the san gabriel valley that charges a reasonable price for install? or.......someone around the san gabriel valley willing to help me, ill come to your area so u can help me thanks a bunch.
Old Jan 22, 2004 | 10:56 PM
Jester's Avatar
All you need to do is remove the battery first. Then, remove the stock intake completely. Your intake should have come with a post-looking thing. That goes on one of the screws that the stock intake was removed from. Then, you will need to remove the sensor from the stock and put it on the injen intake. Then, mount the filter on the pipe. Make sure it's tight and won't slide off. There should be a rubber-looking thing that screws into where the battery sits, so that the intake can rest on it. Finally just mount it on the throttle body and screw it onto the rubber thing and make sure the filter resides behind the headlight and plug in the cables. Hope this helps...
Old Jan 22, 2004 | 11:10 PM
Exclusive's Avatar
Well I would help you if you were a little bit closer, well unless you want to make the drive out this way If not then it wont be to hard to do it yourself specialy with the install tips just givin above.
Old Jan 22, 2004 | 11:19 PM
TheRedBox's Avatar
You can do it in less than 10 mins.
Just do what he said.
Old Jan 23, 2004 | 12:28 AM
morph1119's Avatar
thanks jester that helps a lot, i knew i count on reply right away.peace outs
8URAWD
May 2, 2018 02:22 PM
slowcelica
Feb 10, 2015 02:32 PM
arinvolvo
24
Nov 2, 2003 05:30 AM
eric_m
29
Oct 12, 2003 08:22 AM
kidkamel
Oct 10, 2003 06:41 PM
