CEL?
Old Sep 22, 2009 | 06:31 AM
TRD-71's Avatar
Default CEL?
ok im about to get a intake for my 09 tC.. im reading all this stuff every where about the CEL light turning on and staying on? is this true? Is there anything you can do to turn it off for good? i dont want my brand new trd tC to have a CEL light on!
Old Sep 22, 2009 | 06:33 AM
DJ08tC's Avatar
Uhm if they got a CEL they didn't install it right. There are plenty of people that have installed them with no problems.
Old Sep 22, 2009 | 02:07 PM
TRD-71's Avatar
then why have i read many posts about people installing them right and the CEL still comes on?
Old Sep 22, 2009 | 02:14 PM
TunerKid's Avatar
i think you might be talking about headers. headers will throw a code because it deletes the cat. an intake should never throw a code unless there is something wrong with the MAF sensor.
Old Sep 22, 2009 | 03:48 PM
rangerryda's Avatar
No CEL from a properly installed intake. Even the E-Bay ones don't throw codes. Header, yes it may if you don't use an anti-fouler.
Old Sep 22, 2009 | 04:38 PM
skinnayyy's Avatar
Team Scionara
^x3249871
Old Sep 22, 2009 | 04:51 PM
draxcaliber's Avatar
okay, basic instructions for installing a cold air intake.
1. disconnect battery (lots of people don't and then short out their MAF which is dumb and very expensive part to replace.
2. remove stock intake assembly, be very careful with the maf sensor and make sure you don't get it get dirty as this can also cause a CEL.
3. install cold air intake. pay close attention to instructions, diagrams and torque specs, make sure everything is tight and no air leaks, properly reinstall MAF sensor.
4. double check your work, make sure everything looks, and then reconnect the battery.
5. start car and let it idle for 10 minutes so it can adjust to the new air flow through the CAI.
6. DO NOT FREAK OUT AND POST ON HERE THAT NOW YOUR WINDOW SWITCHES AND SUN ROOF SWITCHES DON'T WORK. they need to be reprogrammed, which is pretty much done by holding down each of the buttons for like 5 seconds straight or whatever. the owner's manual tells you. it has to be done everytime you disconnect the battery and needs to be reconnected.
Old Sep 22, 2009 | 09:49 PM
TRD-71's Avatar
thats what i was thinking, the only way to throw a code would be to F*** up the MAF. sounds good! ill be getting an injen intake very soon. thanks guys!
Old Sep 23, 2009 | 02:48 AM
Steventc07's Avatar
um........it would help if you read the code.......then we could tell you how to fix it.......not just ignore/suppress it
Old Sep 23, 2009 | 02:50 AM
DJ08tC's Avatar
^^Dude what are you talking about, he wants to get an intake and has heard a lot of people get a CEL and wanted to know if it was true. He does not have a CEL
Old Sep 23, 2009 | 03:11 AM
TRD-71's Avatar
^^Thank you!
Old Sep 23, 2009 | 06:50 AM
XIEmperorIX's Avatar
The only intake people were having problems with CEL codes was the Fujita and I think the Tenzo intake? and with the Fujita ones I think it was just the earlier models. Otherwise as long as everything is properly installed you won't have an issue..had my injen for over 2 years now and no issues..
Old Sep 23, 2009 | 01:12 PM
DJ08tC's Avatar
Yea I think fujita had a problem because the whole thing was 3" so it was too big for the MAF senor to read the air flow right. So they made it like the injen and drop the MAF section down to 2.5". I think that was it.
Old Sep 23, 2009 | 02:27 PM
The injen is 3" *Shrug* so I don't know if that was the issue
Old Sep 23, 2009 | 03:17 PM
DJ08tC's Avatar
Yea it is 3" but at the maf it steps down to 2.5"
Old Sep 23, 2009 | 09:33 PM
TRD-71's Avatar
im gunna the injen intake but im not sure if i want chrome or if i want black..my whole car is black due to being a rs5.0..so im thinking the black one might be too much black??
Old Sep 23, 2009 | 11:36 PM
DJ08tC's Avatar
Never liked chrome, but it is up to you
Old Sep 24, 2009 | 12:31 AM
charlie07tc's Avatar
I had on 07' fujita intake, first had no problems at all except that the holes to screw the maf on were off by a very small margin. I got hit and after the body shop put it back together i threw a CEL, code was for the maf. Tried replacing it, didn't work, heard about the diameter issue with fujita intakes so i sent the maf section back. They sent me the replacement with the smaller maf section..... it also threw the maf cel. I tried something suggested by one of the guys in my scikotcs chapter, I got a tube of clear silicone and removed the maf and lined the hole on the intake where the maf goes in, reamed out the holes where the screws go into the maf, reinstalled the maf and drew a bead of silicone areound the maf and let it dry..... bye-bye cel, and it has never returned.
So If you get a cel cause of a cai, try sealing it with silicone.
Old Sep 24, 2009 | 01:13 AM
Steventc07's Avatar
my b.
yea injen is the way to go, I had one and had no problems.
Old Sep 24, 2009 | 04:27 AM
User 112921's Avatar
injen is 3 inches?? how come mine looks only like 2.5..
whooty
Apr 19, 2023 05:34 PM
MeDizzy
Oct 8, 2015 03:31 PM
BigIrish
May 18, 2015 12:04 AM
xb4lf
Apr 4, 2015 07:15 PM
D_Roke
Mar 31, 2015 05:37 PM
