white smoke coming out!!!
Old Feb 7, 2010 | 12:32 AM
Dkfung88's Avatar
Default white smoke coming out!!!
so after we put the new turbo in there and let it run for a little bit, when we rev there is a big puff of white smoke that smells like oil. we took the turbo apart and looked at it and sure enough there was a lot of oil in it... my question is, is it my oil feed/return line? im using -6 and -3 for oil lines... does anybody know the size of the lines that other kits are using?
Old Feb 7, 2010 | 12:41 AM
ElevationTC's Avatar
Is ur return line kinked?
Old Feb 7, 2010 | 12:51 AM
Hix's Avatar
Hix
sounds like too much oil pressure or a clogged/kinked drain tube.
Old Feb 7, 2010 | 01:09 AM
Dkfung88's Avatar
Originally Posted by ElevationTC
-10 -4
is this a custom line? yeah we're using -6 and -3.... too small huh...
Old Feb 7, 2010 | 01:11 AM
I always use -10 or half inch return line!
Old Feb 7, 2010 | 01:16 AM
Dkfung88's Avatar
regardless of what turbo? im using a t3t4
Old Feb 7, 2010 | 01:18 AM
Turbo doesnt matter.. If its journal bearings. use no resitrictor..
Take a pic of the return line for me!
Old Feb 7, 2010 | 01:23 AM
Dkfung88's Avatar
dang =( the earliest i can take a picture is on Monday... car is at the shop.. but i think u hit the jackpot there, we were using -6 return lines and -3 feed
Old Feb 7, 2010 | 01:27 AM
-6 for a return line i think is to small.. bit im no turbo expert or anything
Old Feb 7, 2010 | 01:31 AM
crush02342002's Avatar
I agree -10 is a standard return line
Old Feb 7, 2010 | 01:35 AM
YUP, I switched my ptuning kit to a 3/4 line when i was having a smoke issue.. turns out i had the line kinked.. but i changed anyways!
Old Feb 7, 2010 | 01:40 AM
why put a -8? Use the -10.. or goto lowes and get a 3/4 hose and use it! do it right before u blow the seals out of the turbo.
Old Feb 7, 2010 | 01:44 AM
seals should be ok as long as you get this issue taken care of asap. the seals are pretty much a small version of a piston ring. thats not saying they cant be damaged.
Old Feb 7, 2010 | 01:50 AM
YUP.. its not really a "seal" as everyone knows it to be! But with to high of oil pressure build up it has to go somewere! I reallly need pics!
Old Feb 7, 2010 | 01:52 AM
Dkfung88's Avatar
lol i'll take some pics monday... i have pics of everything put back on... where it would look nice but no pics of the actual set up yet... haha my VRD fogs and bumper fits perfectly with no modifications!!
Old Feb 7, 2010 | 03:12 AM
gompka's Avatar
mine did it when my rings were toast and there was too much pressure in the crankcase/oilpan, similar to running a smaller line as it restricted oil return.
Old Feb 7, 2010 | 04:23 AM
deathbyc4's Avatar
It's either the line is kinked, too much crankcase pressure, or the valve cover is not vented correctly. I've experienced all three
Old Feb 7, 2010 | 05:05 AM
Dkfung88's Avatar
crankcase pressure? valve cover? lol sorry im a newb here with turbo... how would we tell and be able to adjust those?
Old Feb 7, 2010 | 12:55 PM
Ace83's Avatar
Ronin Scion
i agree, must be oil drain restriction.. -10 is always recommended as it allows better by gravity, remember oil return is not pressurized at least you dont want it to.. but if it doesnt resolve you might have other problems too
Old Feb 7, 2010 | 04:00 PM
deathbyc4's Avatar
the valve cover has two ports, one on the driver side and one on the back going to a PCV valve to the intake. make sure those arent kinked in any way, then check the driver side port to make usre its not blow out air/oil/water/small animals when at idle.
