white smoke coming out!!!
Old Feb 17, 2010 | 04:11 PM
  #61
cburglb34's Avatar
Originally Posted by Dkfung88
i agree...... but they just overlooked it... i brought it to a shop to get my turbo installed... then brought it over to another shop to solve that problem
LOL a shop did this to you? ahhh i would sooo be on their ___
Old Feb 17, 2010 | 04:12 PM
  #62
Ace83's Avatar
Ronin Scion
how does the car run or idle right now. i hope your engine is not full of gunk from burning those oil.. you might consider doing some seafoaming
Old Feb 17, 2010 | 08:46 PM
  #63
Dkfung88's Avatar
its a buddy's shop....
i actually might use some seafoam after its done tuning... idle is running really rich... like... really really rich
Old Feb 17, 2010 | 08:54 PM
  #64
cburglb34's Avatar
make sure u buy a set of plugs for after the tuning session becasue 1. your plugs are now fouled, 2 they will get worse during tuning
Old Feb 17, 2010 | 09:08 PM
  #65
crush02342002's Avatar
^^ yeppers
Old Feb 17, 2010 | 11:51 PM
  #66
Dkfung88's Avatar
uh oh.. problem! it says i have a misfire in cylinder 1 and 4 and they tried unplugging the injectors and it doesnt make the car bog or anything whereas if they unplug injectors 2 and 3 the car sounds like its about to die...
any ideas?
Old Feb 17, 2010 | 11:52 PM
  #67
Dkfung88's Avatar
oh we also checked the coils and the coils are good.... plugs are ok....
Old Feb 18, 2010 | 01:07 AM
  #68
wtf???
Old Feb 18, 2010 | 01:20 AM
  #69
cburglb34's Avatar
take a long flat head screw driver and put the handle to your ear and the tip on to the injector one at a time each injector should be giving off a clickign sound if they dont then u have a problem in either the wiring or the injector
Old Feb 18, 2010 | 01:43 AM
  #70
Dkfung88's Avatar
they're sending in the injectors to clean tomorrow.. since i bought them used, they're guessing its just dirty injectors... i drove from my friend's house to the shop and it didnt throw a CEL till we pulled up to their driveway... but lets hope its just dirty injectors..
Old Feb 18, 2010 | 01:56 AM
  #71
cburglb34's Avatar
well by the way u described ur idle and everything ur def having injectors not opening....
the car will trim out enogh fuel to keep the car at 14.7 with as large as 550cc injectors, any bigger and ull be richer but u wont be sputtering and bogging like u are, right now im on 550cc injectors with my aem fic bypassed till i get to ptuning and can driv eaorund town runnign 14.7 afr in closed loop
Old Feb 18, 2010 | 02:15 AM
  #72
Dkfung88's Avatar
yeah it was weird, he was showing me how the car adjusted itself by unplugging the two cylinders that were misfiring (1 and 4) and when he unplugged the injectors, the car bogged a little but when he unplugged one at a time for the two working ones (2 and 3) the car felt like it was about to die... he cleared the code and waited a few minutes and it came back saying its misfiring in cylinder 1... i've always had problems with that cylinder and it went away after i moved the injectors around.. i remember swapping cylinder 1 and cylinder 4 injectors to see if it threw any code and yup, now injector 4 has a problem as well as injector 1.....
dont know if all that made any sense lol...
he was messing around with the afr to see if it made any difference but it was still sputtering so he came to this conclusion that it was dirty injectors... at first the map was set to -50 and he brought it back up to where my afr was 14.7 but it was still acting up...
Old Oct 11, 2010 | 06:03 AM
  #73
gsx1000rtc's Avatar
blow out air/oil/light smoke when at idle. __________________mines does that?? what that means, i checked compression and all cilynder were in 180psi, plus mines smoke something on the exhaust
Old Oct 11, 2010 | 06:06 AM
  #74
gsx1000rtc's Avatar
Old Aug 6, 2012 | 02:05 AM
  #75
motoxxx87's Avatar
OMG I just did the same thing hope these fixes it and i didnt mess up my motor or turbo seal!!!
no more white smoke! This was our problem... we pulled it and plugged it up on the intake side..
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
kahsperr
Regional - Pacific South
Mar 26, 2015 06:25 PM
NewBox06
Feb 3, 2015 04:02 AM
DAHOZZMAN
Dec 16, 2014 06:48 AM
randode
10
Dec 11, 2003 06:05 PM
