How to test Mass Air Flow Sensor
Old Mar 10, 2010 | 10:08 PM
mauiXaXbTc's Avatar
Default How to test Mass Air Flow Sensor
Does anyone know how to test the Mass Air Flow Sensor to see if it is working correctly. I had it cleaned by a master mechanic using MAF cleaner and I am not getting the gas mileage that i used to prior to the cleaning. Any info will be appreciated.
Old Mar 11, 2010 | 12:04 AM
my06tc's Avatar
hmmmm.i really dont think there is a way to test it...either it works or it does'nt, as far as gas milage it could be other things other then the MAF
Old Mar 11, 2010 | 01:47 AM
Metro273's Avatar
You need the service manual for your ride cause the MAF specs are in there. There is a way to check the specs out!
Old Mar 11, 2010 | 03:53 AM
ajcadoo's Avatar
yeah, i am pretty sure the MAF is an all or nothing kinda deal. if it is broken you will throw a ton of lights and have that 3000RPM limiter. Yeah, gas mileage might be something else. (weight, tire pressure, weather, etc)
Old Mar 16, 2010 | 05:29 AM
tanakasan's Avatar
Sprayed on a clean cloth then clean MAF...or sprayed into MAF? Heard you should not spray directly into MAF.
Robert
Old Mar 16, 2010 | 07:50 AM
DeathStalker's Avatar
disconnect battery and let the computer reset its parameters. a clean maf can throw off the computer.
hydrogen
Jul 14, 2020 09:41 PM
Greg S
Feb 19, 2015 07:17 PM
hotroddelux
Dec 3, 2014 11:33 PM
eric_m
79
Mar 17, 2013 12:21 AM
badwinger
16
Feb 6, 2004 10:23 AM
