does the timing chain need to be different?
Old Mar 30, 2010 | 02:29 PM
craftedinsane's Avatar
Default does the timing chain need to be different?
i bored my motor out and other work done too. when i picked up my motor, he showed me that everything was lined up with the timing chain, but i installed the motor last night and would not crank. should the timing be set to different specs?
Old Mar 30, 2010 | 02:43 PM
trd07tc's Avatar
no
Old Mar 30, 2010 | 04:53 PM
yamaha16bw's Avatar
Everyone that has had this issue says claimed to have installed the chain right but come to find out they didnt. Get a toyota service manual and check your guys works. I bet its off.
Old Mar 30, 2010 | 05:38 PM
thendawg's Avatar
Everyone's using the wrong alignment marker on the exhaust cam... Ive seen like 4 machine shops do this that assembled 2az's. The exhaust cam has 3 markers on the gear, two dots, one with I, one with E, than a third hash with no letter - it needs to be aligned to the hash, not the other 2 - everyone seems to use the E which will cause it to be like 30-40* off and no fire. lucky we dont have an interference motor or the consequences could be MUCH worse. Also make sure the intake VVTI gear was locked when installed - i believe its the full retard position. When you rotate the crank the lobes on E and I cams should be almost 180* off from ea other. Of course also make sure to check timing by setting crank to 0* than see if the cams are at the alignment markers.
Old Mar 30, 2010 | 05:43 PM
Murphys_Law's Avatar
bump for future reference
Old Mar 30, 2010 | 10:21 PM
thank so very much, that information just saved me so much time. i called the shop and asked where he timed it on the exhaust and for sure, he marked it on the E. reasons like these is why i love my car, to get information about it is as easy as a post!
Old Mar 30, 2010 | 10:25 PM
thendawg's Avatar
Someone should start a sticky for motor building FAQ/Info lol. BTW - you CAN adjust the timing with timing cover on/in car - but its a pita - ive done it
Old Apr 1, 2010 | 01:45 AM
yea i did that, too forever to get the chain to line up right those two yellow chains are the worst things ever.
Old Apr 1, 2010 | 04:29 AM
trd07tc's Avatar
so its running?
eatcrispycreme2
Jan 30, 2015 03:42 AM
paul_dezod
Jan 5, 2015 02:07 PM
Yakimaniac
Scion xD Wheel & Tire
Nov 22, 2014 04:20 PM
eric_m
79
Mar 17, 2013 12:21 AM
Scionic
39
Jul 20, 2004 02:46 AM
