Scion xD Aero & Exterior Aero parts and exterior dress items...
How To: Remove Wiper Arms, Upper+Lower Wiper Cowls, & Motor Assy
Old Apr 24, 2010 | 03:38 PM
asurjc's Avatar
Default How To: Remove Wiper Arms, Upper+Lower Wiper Cowls, & Motor Assy
I just spent 2 days off doing a few interior enhancements one of which, included running an Amp power wire. To do this, I had to remove the whole wiper setup to gain access
to the firewall grommet mentioned in cobaltbravo's dash removal thread. This would probably also help for those of you needing to access the front strut towers.
Here's how I did it:
Begin by pulling the caps off of the wiper arm bolts. Mine took a pretty good pull.
Next, remove the wiper arm nuts. BE CAREFUL as you unscrew the driver side nut if using a socket because the wiper cowl has a built in chute (see arrow)
that will send the nut where you really don't want to have to go to retrieve it if it falls out of the socket.
(if this happens to you, see the note at the bottom of this post)
Once you have the wiper nut off, grasp the lower part of the arm and pull hard while shaking gently. The arm should come loose after a bit.
Now, raise the hood and detach the weatherstripping from the upper wiper cowl by disengaging the yellow clips.
After you have set the weatherstripping aside, remove the brake fluid reservoir access by disengaging the 2 clips at the forward end.
Next, remove the fasteners at each forward corner of the cowl by pulling the center pin up first, and then the entire fastener.
Now, snap out all of the retention clips that secure the upper cowl to the lower cowl. There are a lot of them so make sure that each one is fully released before you proceed (I broke one).
Next, gently remove the upper wiper cowl. I found it easiest to rest the hood on my head so I could lower the hood peg out of the way.
(At this point, I removed the battery because it was going to have to come out anyway for what I was doing. Plus, it was getting in my way.)
This will now expose the wiper motor and driving assembly. To remove this, disengage the 2 motor wiring harness clips and remove the 2 black bolts securing
the motor assembly to the lower cowl. Once the bolts are removed, gently slide the whole assembly in the direction of the arrow and pull it away from the firewall.
Next, remove the wire harness plug from the wiper motor so the whole assembly can be set aside.
Now, on to the lower wiper cowl: Remove the 2 10mm bolts securing the wiper assembly mount to the lower cowl and
then remove the rest of the bolts securing the lower cowl to the firewall (there are 10 total including the 2 I just mentioned).
Lastly, remove the one lone plastic clip on the passenger side next to the hood hinge before removing the entire lower cowl.
And there you have it. Re-assembly in reverse order of course. Since the wiper studs are grooved, it is pretty easy to get the arms right back in the orientation they were in when you took them off.
NOTE:
If the driver side washer arm nut fell down where I mentioned, here's probably what will happen: If your car is sitting on a level surface, you will hear the nut bounce off a few things under the hood. After a substantial amount of searching, you will find it just barely visible resting precariously on the back of the headlight assembly behind the parking/turn signal lamp deep into the quarter panel. Try to get a hold of it here because it gets worse if you can't......If while reaching for the bolt you manage to knock it off the back of the headlight,(as I did) hopefully you will hear a couple more bounces ending with a hollow 'THUD.' This is the sound of the nut finally coming to rest in the deep hollow created by the wheel well splash-guard and the front bumper. To get to this location, remove the 2 gray bolts circled. This should give you enough room to gently separate the splash-guard from the bumper to get your hand up in there to grab the nut.
Old Apr 24, 2010 | 11:49 PM
Davestoaster's Avatar
Beautiful !!!!!!!!!!
The only thing I would mention is:
Before pulling the wiper arm off, and after removing the nut, try to mark it's location on the splined wiper shaft. If you are a spline or two off, the wiper might hit the A pillar, or bottom out on the cowl, when in use on a rainy day.
Thanks for the GREAT write-up !!!!!!!!!
Old Apr 25, 2010 | 05:29 AM
cobaltbravo's Avatar
Default Re: how to remove wiper arms, upper+lower wiper cowls, motor assy
Very nice how to. Hope my old write up helped out with your wiring.
Sent from my Droid using Tapatalk
Old Apr 25, 2010 | 06:06 AM
YELOSUB's Avatar
Wagonistas
Nice write up...I've taken mine off before using the same methods you described...To make sure your wiper arms go back in the same place just use blue painters tape and mark underneath the bottom of each blades on the front windshield...Mods should sticky this...
Old Apr 26, 2010 | 12:42 AM
asurjc's Avatar
Yes. Your old write up helped me immensely on my projects these past few afternoons off. I'll have more to come in the near future. Thanks again.
Thanks gentlemen for the kind words. These are both far better ideas than my trial and error method. All I did was to leave the wipers in their 'pulled away' position, lightly seat them on their respective studs, and lower them briefly onto the windshield to see if they were exactly parallel to the plastic upper cowl. It was pretty easy to tell when they were seated right. From that point, I just secured them down with their respective nuts, did a 'test wipe' and called it good.
Old May 14, 2010 | 12:30 AM
asurjc's Avatar
I should also add that when you're re-installing the lower wiper cowl, do pay close attention to the orientation of the front washer fluid line on the passenger side corner. The cowl should go UNDER the line not on top of it. If you accidentally place it on top, the washer line will be squished and kinked so as to not allow any washer fluid to get to the front windshield squirters. This is probably obvious to most of you but it wasn't to me......(cell phone pic)
Old Feb 24, 2018 | 04:49 AM
MR_LUV's Avatar
Administrator
Administrator
Thumbs up
Excellent Write up!
Old Feb 25, 2018 | 09:33 PM
DAlex's Avatar
Originally Posted by MR_LUV
Excellent Write up!
Hey, nice praise.....even if the thread was posted 8 years ago.....
So....just WHY did he remove all this stuff? I forget....
Oh, BTW, a good way to keep from dropping nuts out of your socket: Put a magnet on the side of the socket.
Old Feb 26, 2018 | 10:48 AM
MR_LUV's Avatar
Administrator
Administrator
Instead of criticizing the AGE of the thread, you should concentrate on the CONTENT. FYI, there are many Owners with cars that are 8 years old or less that may find the information useful.
It has over 15,000 views Including Yours. You seem to have a problem with older threads:
Sticky DIY-Under Seat Subwoofer Install: what I did (pic heavy) with over 41,000 views.
If you are Clueless, Read the OP's 1st post in the Top of this Thread above ▲▲ LOOK UP! ▲▲ Smh..
Administrator
____
Old Feb 21, 2020 | 05:57 AM
MR_LUV's Avatar
Administrator
Administrator
Becomes a Sticky
MR LUV
__________________
Old Apr 10, 2021 | 07:44 PM
Lost10mm's Avatar
Default Thank you so much
I appreciate the heck out of you, this helped me so much and saved me a couple hundred $ at a shop lol
18TTony
May 10, 2016 02:25 AM
garabaldy
Jan 31, 2016 11:14 PM
jct
Scion xA Aero & Exterior
Mar 29, 2005 11:22 PM
Stardumb
Jan 25, 2005 05:59 PM
UnFocused
Jul 2, 2004 08:38 AM
